Nokia 2600, can't open, and turning off when turned on.
1. I can't open my nokia 2600's back to get to the battery. 2. Everytime I turn it on it turns right back off. It's getting really annoying. And the phone is AT&T
Re: Nokia 2600, can't open, and turning off when turned...
When you change the battery? is it old replace the new one,if new the battery may be loose on the cabinet.make this comfortably.and the BSI pin on the mobile may disconnected,do the above if repeat send replay.
Nokia 2600 classic MORE PICTURES. Released 2008, March 73.2g, 12mm thickness. Feature phone ... Battery, Type, Removable Li-Ion 870 mAh battery (BL-5BT).
try to put back the old sim card.. if u have the same problem with both the sim cards, then it must ba the display proble. your battery can be checked by inserting into another similar compatible phone.
PHILIP
hi,your phone battery is not connected to connectors or ur battery is dead.i give two options
1.try to connect the battery & connectors.
2.replace new orginal battery.
thank you.
try to delete some of your text messages. free up some spaces for your phone memory. you can back it up if the messages are really that important to you by using nokia pc suite.
hello 1_ can you save your formation in other phone . 2_that code format your phone for Nokia only 3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345 4_ other numbers *#7370# and the security n ...... and look if the problem is solve it because after this . you have like a new mobile
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
S
