Ovens Logo
Posted on Jun 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating element. now nothing gets hot. but the oven comes on and sounds like it it is working lights, timer, temp set and cleaning setting works but nothing happens in the oven.
Thomas F. Schneider
Level 3:
  • Master 2,715 Answers
  • Posted on Jun 11, 2009
Thomas F. Schneider
Master
Level 3:
Answers
2715
Questions
Helped
1106563
Points
6961
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
1helpful
Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
1helpful
Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
1helpful
2answers
GE Electric wall oven
Not sure I can help you but will certainly try. Certainly sounds like the heating element - if not possibly a blow fuse. If you have a tester as in a light tester or proper electrical tester you should be able to turn the element on and test to see if it is getting power. If it isn't it may well be a fuse in the wiring. A lot of ovens these days do not have fuses and rely on the mains having a Safety Switch. Taking this into account I would say it is the element which you will need to remove so you can obtain a new one. With elements on most ovens you have to remove them from inside the oven and sometimes have to remove the back panelling to get to the wires to disconnect them. When you do make sure the power is turned off. Hope this helps.
Regards
Bryan
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
