Door leak in LG LDF6810ST Built-in Dishwasher
Your drying vent tube is probably leaking inside the door panel. Remove the outer front panel and on the top left side, there is long white plastic tube connected to the dryer fan assembly. In that connection is where the problem is. You will need to disassemble the fan from the door, disconnect the tube from the fan, clean out the water and debris and use silicone when reassembling the tube to the fan.
