SOURCE: Plays Records Too Fast
If it is a belt drive model it might be that the belt is out of place and therefore causing the speed to be wrong. This might be due to age or wear of the belt. I would look at that before adjusting.
If it is good and you can't see any mechanical fault causing it. Then look for a preset pot (or two) on either the pc board or on the motor itself. They will adjust the speed. If you find two - one will be for 45 they other 33.
Bear in mind the motor might have gone wrong!
