Hey! I have to admit I am feeling my way about in the dark with technology which is embarrassing since I'm only 25... I have a olympus x-43 which I haven't actually used in over a year, but I do want to transfer the old pics (which I can still view via the camera) from it, onto my new laptop. I installed the programme ib and inserted the 4GB SDHC card. In the "My Computer" folder the sd card is being registered and displays that a portion of the memory capacity is being taken up. But, when I try to actually view the files so I can copy/paste it displays that the folder is empty. Similarly ib tells me that there is no new media to transfer. I have the sd card switched to unlock. What in gods name am I doing wrong?! K
Most digital cameras have a small internal memory and an expandable one (SD card). Are the pictures actually stored on the card or in camera memory? If on the card then I suggest a card reader device, if on the camera you need to connect the camera to your computer via its USB cable to access them, unless there is a way to transfer them to the memory card (not all cameras can do this).
SOURCE: camera memory card errors/computer doesn't recognize
Can you get a memory card reader that works for a Mac? If so then loading pic's to the 'puter through that route Flashing red and green lights have a meaning- what does the manual say?[Check the more comprehensive manual on the Software disk] You could buy[or borrow] another card- nothing wrong with having more that one. Also try the card in another camera and a fresh card in yours[Take it a photo shop to try this]
SOURCE: Olympus mem card will not copy pictures onto computer,PLEASE HELP
Not that I know of.
All cards have to be formatted before use.
SOURCE: Copy camera images to memory card through camera
In the camera setup menu there should be a backup option that allows you to copy the images from the internal memory on to the xD picture card.
SOURCE: memory card cannot read by digital camera.
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - go to format option- You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
SOURCE: i have a SP-800UZ olympus
Can you view the pictures in the camera directly? Are the pictures on internal memory or on placed SD card? If the pictures are NOT shown within the camera or when you put in a SD card and your pictures are on internal memory... you can change the menu settings accordingly. If pictures are not shown in the camera, you might want to try the camera Data Repair option: Manual page 41. Check if the camera is seen by the computer as USB Removeable device. You can also manually transfer the pictures with e.g. the Windows Explorer.
