Mac OS Repair
To run Disk Utility on apple macbook OS X 10.4.x, you must start the computer using an Apple Software Restore disc.
Insert the disc into the computer, restart.
After you hear the startup sound, press and hold the "C" key. Hold the key until you see the gray Apple logo.
Your computer will take longer to startup, be patient, this is completely normal. After the CD or DVD is loaded it will automatically start the OS installer, do not reinstall your OS system!
If you are requested to choose a language, just click the right arrow button (Next).
To open the Disk Utility Click on Utilities > Disk Utility.
Now the Disk Utility window should be open. Choose from the left side of the window the hard drive you wish to repair (in this case Macintosh HD).
Make sure that the First Aid tab is selected.
Click Repair Disk button (bottom right).
The tool will check your hard drive, if it encounters any problems it will list them in the middle of the window, otherwise you'll receive this message - "The volume Macintosh HD appears to be OK".
Once the scan is over if it found problems, click again on Repair Disk, this will try to repair the problems, if not successful you need a more advanced utility tool.
