My digi cam is not switching on. the battery has been charged to full and is placed correctly. it was working fine till last week.
If nothing is wrong with the camera, the battery is placed correctly, the battery cover is closed correctly then only one thing can be wrong. Even when you don't believe it is possible, the battery can be flat again.
So to make sure everything is as you think. Charge the battery again, and look if the charger acts as usually. The charging lamp turns orange and charging begins. When the charging is finished, the lamp turns green. Last time you charged, it could have taken 4 hours, before the lamp went green. If the battery is recently charged, it only will take a fraction of that time. If it still takes a long time, your battery was empty. It is recommended, to charge not longer than for 24 hours. After charging, please wait till the battery is cooled down. Then insert it again and close the battery cover. Check the cover closes correctly. And now switch on again.
If you charged with an USB cambs connected to the camera. Don't forget to remove the cable, because the camera won't start as long as an USB cable is connected.
SOURCE: canon powershot g5 - battery charge
Take out the battery and put it back and than recharge again. Some times in case of G5 it happens that the camera battery is not properly charged and the indicator shows that its fully charged (i.e. Green light) In such cases battery need to be taken out and than put back again and recharged
Regards,
Zain
SOURCE: Canon Powershot SX110is: problem with the batteries
Make sure you are using Lithium batteries. Alkaline batteries will go dead immediately in this camera. I've tried it.
SOURCE: canon sd870 says "change battery pack" even though
My IXUS 860 IS behaves the same. I found that if you start it in replay mode and then half press the shutter button it generally starts up OK.
SOURCE: Canon PowerShot G9 stopped working
A common problem on the G9 is they get a loose screw inside and often it renders the camera useless with no power after that common short. There's a site you can get these fixed very reasonably and they include the correction to those internal screws so it won't keep happening. The site is: www.camerasandparts.com The do superb work on the canons for about half of what canon wants to fix these cameras. Good luck with the problem on yours.
