The timer has stopped working - if I set it to dry for 30 minutes the timer doesn't go down and it keeps drying.
SOURCE: Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
SOURCE: dryer working but no heat
Your dryer has two separate fuses, one to turn the drum, and one to heat it. It sounds like you have a broken fuse. Unless this is a new installation, then you need to make sure you have the proper electric cord attached. If it's mistakenly connected with a range cord, it won't supply enough power to the dryer.
SOURCE: Tumble dryer blowing cold air
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
If you are having problems with your gas dryer not heating
the most common problem is that the ignitor goes bad. Even though it glows
sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different
things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
