Inglis 6.5 Cu Ft Super Capacity Gas Dryer Logo
A
Anonymous Posted on Feb 25, 2014
Dryer turns, but no heat to dry clothes
It was a windy day when this unit stopped working. Does this use a spark plug or pilot light? Dryer will tumble but there is no heat. Either way, how do I get the heat going again?
3helpful
Dryer runs but does not heat. It runs continually
If your dryer never quits on its own, then your main selection switch may be bad. Even if the clothes don't dry, the timer should still only run to the end of the cycle and then stop. The problem with the lack of heat could also be caused by a bad timer switch, but that is rare. Usually it is caused by a bad igniter/heat sensor unit. Sometimes you can use a piece of sandpaper and clean the carbon off of the sensor and then it will sense heat when the pilot flame starts, then it will let the gas valve send gas to the main burner. The heat sensor it the part that is in the flame of the pilot light.
Kenmore 11066912690 dryer stops working
if you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
My dryer is heating up but isn't drying the clothes
I would be REALLY suspicious of the exhaust vent. If the dryer is heating up and the drum is turning, it has to dry the clothes UNLESS there is no air going through the dryer. Disconnect the air outlet flexible plastic duct at the back of the unit, and turn it on. If there is no or very little air coming out, the inside of the unit will be plugged with lint. If there is lots of air coming out, the exhaust duct or the outside flapper will be plugged. Sometimes if the exhaust is routed through a cold space there will be so much condensation in the duct that it will droop and literally fill up with water.
1helpful
Pilot working but will not dry completely.
Check the burner vents--both intake and outlet for lint plugging. With the pilot working, it is supposed to heat a thermocouple which generates electricity that opens the main gas valve.
3helpful
No heat coming on to dry the clothes
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 06, 2009 • Dryers
3answers
Finding pilot light for a Kenmore dryer model # 97581110
theres no standing pilot in dryers is it on a heat setting or air dry .then look thru that small hole while in aheat setting on the timer. when you press the start button you will hear two clicks the see the glow ignitor glowing.if its not glowingyou would need to check voltage at the ignitor if no voltage problem will be thermol cut out fuse
Jan 01, 2009 • Dryers
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
Roeper Gas Dryer not heating
 If your unit has a standing pilot, is the pilot lit?  If not, push the Basso control button and light it according to the instruction sticker.
Next, the main thing you should suspect is the capillary tube.  This thin tube runs from a hollow bolt on the gas control to the gas burner. If defective, it will not allow the unit to light off further.  Remove the tube, take it to the hardware store and get a replacement and install.  If these two items don't fix the unit, get professional help.
2helpful
2answers
Dryer smells of natural gas
Of course, this applies to gas dryers only. If you smell natural gas near your gas dryer, do not light matches or a lighter and don't operate electrical switches or anything that might spark, igniting an explosion. Immediately shut off the gas valve that serves the dryer. If the smell is mild, ventilate the area, wait until the air is clear, and re-light your pilot light. If the smell is strong, move everyone outside, leaving the doors open to ventilate the house. Turn off the gas supply valve --located by the gas meter on the gas inlet pipe-- by rotating the valve one quarter turn with an adjustable wrench. The valve's oblong stem should be perpendicular (at a right angle) to the inlet pipe to stop the flow of gas. Call your gas supplier (or the fire department) from a neighbor's phone or a cellular phone outside the house.
Top Inglis Dryers Experts
john h
Are you an Inglis Dryer Expert? Answer questions, earn points and help others
