Canon iR 2020i Laser Printer Logo
A
Anonymous Posted on Feb 24, 2014
KANON IR2020 SYSTEMFEHLER E808 SYSTEMFEHLERE808
tip
How i do to eliminate code error e007 in canon ir2020
i have a code in my machine canon IR2020, and i dont now what do
Systemfehler
Systemfehler is a German band, but the translates to "system error"...try changing the menu back to english and then go to the Nikon support web page and see if there is a firmware upgrade available. Good luck!
1helpful
I have a canon ir2016i and it reads system error e808
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was detected.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the fixing drive motor.
- Replace the DC controller PCB.
- Replace the power supply PCB.
If you are not a tech I recomend that you contact one in solving your problem.
1helpful
2answers
Error 001, error 808
the e001 code is something is going with the fixing assembly. one of the thermistors could be going bad.
E808 is a Zero Cross error. We most commonly see power supplies or bad wall voltage cause this code.
The following information is coppied from the IR2016 Service Manual.
  • The heater does not turn on.
  • A fixing drive motor failure was detected.
  • Check the connector of the fixing film unit.
  • Replace the fixing film unit.
  • Replace the fixing drive motor.
  • Replace the DC controller PCB.
  • Replace the power supply PCB.
M201 - Fixing Drive Motor - FK2-1067 - J202 on the DC controller PCB - E007, E808
Power Supply - FK2-1074
37helpful
4answers
System error E808
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540 0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542 0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744 0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
Code E808
This problem was solved by turning off the unit and unplugging the power overnight. The next morning it worked fine.
old marine
old marine
ZJ Limited
ZJ Limited
