I have replaced the ignition coil, rotary button, and coil but still am not getting no fire to Plugs. What else could it be? Engine turns over but no spark on top of the coil where plug wire connects not at any of plugs. Thanks...
I think you have the VORTEC set-up, look at the CKP & CMP sensor, ECT, TP sensor, IAC, ignition switch, blown fuse/s, timing chain, Bad ground to engine, bad distribtor, bad spark-plug, wires, or distributor cap & rotor. What is the "rotary button"? Well let me know if I can be of anymore help.
Souds like ignition module has failed. Check for 12 volts to mod and replace mod if voltage is good.
SOURCE: I have replaced the ignition coil, rotary button,
If you have the tools, remove the ignition control module (inside the distributor). You can bring it down to AUTO-ZONE and they will test it for free. Other stores may be able to do it too. Is this issue constant, when does it happen? Check the fuse box, ECT, IAC, TP, and the ignition switch. Let me know if that helped at all.
