If breaks are OK and rotors too, cars make all kind of noises.
It could be worn or sticking brake pad or the CV joint is worn out. Try turning around a corner and see if you get a "clicking " sound. If you do, its a sign the CV joint is worn out on what side you are turning. Its best to change both if 1 is worn.
Have your brakes rotors checked. Sounds like they need to be replaced. Do this or you may have to have them turned if they begin to groove
SOURCE: 2004 V6 cold engine noise related to steering - goes away after few miles
check pawer steering pump belt mybe it is worn out or loose, also check the alteranator belt.
SOURCE: Brake clicking
hiya may i suggest you inspect the front brakes pads and discs for wear and discs for damage /scoures considering age of vehicle? when was last service inspection on brakes etc? if you do not feel competant to check brakes ? quite understand you could pop along to nearest national tyres depot and ask them to check brakes as above and also driveshaft cv joints for wear as these cv joints also give clicking sound when driving tyre dpot do not usually charge to check but will try to obtain job and give you a quote! if you have diagnosis and £££££?quote ? by all means come back with update and glad to offer help and advice if you wish ? hope this helps you as to probable cause? either way repair/s will not be too expensive best wishes
SOURCE: Honda Odyssey creaking problem
is there any way to fix it without going to the shop? and you cant fix it your self will it be expansive to take it to the shop?
SOURCE: How do I diagnose a loud whining noise from the
It sounds like it is def. the wheel bearing. If you can get it on a hoist and let it down with something to stop one side of vehicle at a time and let other side spin freely you will likely be able to determine which side. Or if you have no hoist, jack up vehicle one side at a time and spin wheel listen for growling and also move tire in and out to check for looseness.
SOURCE: My honda accord is making a humming noise
it sounds like your powwersteering pump check the fluid level and if its low put powersteering fluid for hondas back in there.
