Question about Roland VersaCAMM VP-540i
Printer dropping blue dots only around black or blue text.
Has been cleaned properly. Small dots almost like it is a low quality image but it is not.
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
I have blue dots on the screen. I cleaned the glass on the projection bulb and the prizm but still have blue dots.
Your tv is an LCD projection one - in which the image is generated by 3 small LCD screens. The blue dots are pixels from the blue LCD that are dead - always fully open.The only fix is to replace the LCD panel and that is going to cost you around $300.
Nov 06, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
HP officejet 7210 hortizontal white lines
I would suggest you get a set of original HP cartridges .. I have clients trying to save $ all the time by buying refilled and/or refilling themselves to only go and get HP brand. Refills just don't cut it .. leaks, poor print quality, unrecognized cartridges .. there are so many things that I can point out .. save yourself the hassles .. get HP
Mar 30, 2009 | HP Officejet 7210 All-In-One InkJet...
Printing from online comes out very light
Typically, the quality of images and text on websites is very low resolution to keep the file size down in order for them to load more quickly on your screen. Just because it looks good on your screen doesn't mean it will print the same. There are just fewer dots per inch in the text and images and they can appear faint and low quality when printed. Look for a print icon on some web pages as it will be at least formatted properly to fit the page and some are of better quality than printing what is on the screen.
When it comes to emails, if the text is in a color, especially blue, they will tend to print light. Change your printer settings to print grayscale and that should help sharpen things up about as much as is possible.
sharvey400
Dec 03, 2008 | HP Office Equipment & Supplies
Black toner does not print properly....
you need a new cartridge this will make it better
Nov 26, 2008 | Samsung CLX-2160N All-In-One Printer
Print quality suddenly degraded
Sounds like your print head went bad. You will have to buy another one.
Jun 04, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Bad color print out
u first check the ink level on the catridges,mostly inks are too low
ink is ok -u use printer utilities like headclean
Mar 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Roland VersaCAMM VP-540i Logo
Top Roland Office Equipment & Supplies Experts
JonSnell Electronic
JonSnell Electronic
Ravi
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
