SOURCE: video out on dimension 2400
uhh dimension 2400 doesnt have rca yellow out or agp. only pci ports.. sounds like u installed a tv tunner and it has a yellow rca INput. not out.
SOURCE: Computer Memory Help!
I would not do it since your computer is recomended for pc 4200(533) and that chip set is recomended for pc6400(800) this matters for the life of the other components not to mention that your computer won't post and could cause dammage, even though your board supports dual channel ddr2 , and I think you should get some memory that is not going to wear your computer down so that you end up having to worry about other repairs also , stay within the recomended speed , so no i wouldn't use those chips in there , and i wouldn't advise someone to do that , but i can see the deal you were looking at!
SOURCE: Unsure of what type of PCI expansion slot in dimension 2400 (2)
This machine will support up to 32bit maximum pci expansion card speed. So it should work. http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm
SOURCE: I want to get a new video card But..
For Motherboard interface:
mini tower version of the Optiplex GX520 appears to have one PCI Express Slot. other cases don't appear to have anything.
Check the photos on the link below to match up your form factor
http://www.dell.com/content/products/productdetails.aspx/optix_gx520?c=us&cs=28&l=en&s=dfb
For monitor, make sure you have a DVi port or something like that & that your card has a matching port or that you can get an acceptable adapter. If monitor not DV capable, HD video card will not help you much.
SOURCE: What cable for Gateway FPD monitor to Dell Dimension 2400 compute
You can either use a dvi or vga cable, for more info go to http://service.gateway.com/s/Manuals/Monitors/8511253.pdf
the problem is when take the desktop to the office, it works with the monitors there ..
i bought 2 new monitors from Best Buy and Office max, they both say no signal.
