Ecoquest Flair Air Purifier Logo
A
Anonymous Posted on Feb 24, 2014
Kozy World service
Need a repairman
1helpful
My professional series ionic breeze gp s1830/961 will not turn on
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
1helpful
Round Metal Disk type thing in Alpine Living Air XL-15
Hi Chipster7_20,
It sounds like the little round electrical spade terminal is what has broken off. If you aren't comfortable working with electrical (this is a fairly high-voltage environment, BTW), you might want to find a local electrical repairman to replace and re-attach it. EcoQuest no longer does support for XL15s, so it's up to little independent dealers/handymen like yours truly to keep these machines going. You could ship it to me, but it would probably cost more for shipping than having a local do the work.
If I mis-understood your description, please write back with more details. If you could reply with a digital picture it would help. (use the little tree-picture icon in the toolbar above to post it).
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
2answers
2answers
Just stopped working
Exactly the same thing happened to me. I get ** response from the unit. I may need to get it serviced from a local electrician as Brookstone is **t helping me.
How do i replace my filter? Please help!!!
Here is the link for the user guide; http://www.holmesproducts.com/pdfs/HAP223.pdf Check page 2 for fitting instructions, and yes the HAPF22 is the right filter. Hope this helps :)
Top Ecoquest Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
