ASKO W600 does have a heating element and only requires a cold water hookup. The temperature sensor will prevent the advance of the cycles until the initially selected temperature is achieved. If the machine is cycling but not making hot water check the heating element and the sensor. The menues for the cycles allow you to choose temperatures; you can check that they are not set low.The warranty is 3 years and then years 4 & 5 ASKO replacement parts for any defective solid-state controls, timers, motors, or pumps. You can also call ASKO directly for help and advice in Richardson,
Texas Customer Service Center at 800-898-1879 or 972-238-0794
Check heater element is getting power
Turn it to the cold setting, See if it becomes hot by putting your hand under water flow. Be-careful not to burn yourself. If it works then switch hoses on rear of machine. / it was hooked up backwards.
ITS NOT SUPPOSE TO HEAT UP THE WATER COMES IN HOT FROM THE OUTLET? THE WATER TEMPERATURE SWITCH DETERMINES WEATHER IT USES HOT OF COLD ECT
