Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Wont start.buzzes.unplug to turn off
Washer stoped in middle of (looks like spin&driin )so hit start door locks, but dont start and buzz'es and have to unplug to get the buzzing to stop and trun off.plug in hit power . hit start door locks and buzz'es while the door and start buttons flash..
    New Friend:
    Problem Solver:
  • 7 Answers
Possible unbalanced load in the washer. I have found this to be the case in other types of top load washers. Just redistribute the load the try again. If this works, washer is doing what it needs to do to keep from spinning madly out of control and extending its life!
Posted on Feb 25, 2014
SOURCE:
  • 65 Answers
SOURCE: My washer makes a buzzing sound but does not spin or pump water out
fl is the code for a pump takind too long to drain. you have the buzzing so hopefull it is just clogged with small sock or debris from a yarn type item. to access pump (there are two types) unplug washer if you can bring it outside as this can hold lots of water. if not have a large wet vac handy. tilt washer 45 degrees to access bottom panel . remove three 5/16 screws, remove panel. the pump has one beige hose,one black. unclip or remove 4 torx screws depending on the type pump. clear pump. re-assemble. if indoors very important to slowly remove beige hose while running vacuum if not several gals of water will rush out. if this is a pump with the grey housing and it occurs immediately you have probably stripped the pump shaft and will have to replace it with the newre style pump. which will be the same procedure just one more step. the pump retails about 88 dollars. good luck
Posted on Feb 18, 2008
IFIXALL
  • 869 Answers
SOURCE: Buzzing noise coming from timer control area
Is your water on ??if yes than you may have a bad timer.
Posted on Jun 07, 2008
  • 1028 Answers
SOURCE: Washer stuck in Drain mode, flashes same time, can't unlock control or pause/stop
ck to see if any water in drum if so possible pump clogged ..remove bottom panel pump will have clean out port with large knob turn counterclockwise ..expect flood if water inside but can't be helped if washer is on pedistal open drawer and try setting bucket underneath and have towels handy..after cleaning reinstall port cover and try again..if no water in tub try unplugging hold power button down 20-30 secs and reconnect still have problem door can be unlocked by removing bottom panel and pulling small tab just below lock assembly from underneath
Posted on Aug 12, 2008
aborcass
  • 2651 Answers
SOURCE: timer light keeps flashing
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up, the drain pump is humming, causeit cant pump any water
Posted on Jan 25, 2009
  • 11 Answers
SOURCE: Waher will not go into spin cycle. It makes a buzzing noise and will not spin.
it's most likely your timer....u can get the machine to spin out your clothes by pushing the timer in and pulling it back out. this resets the motor and makes it turn backwards. it's a pain to do this because you have to keep an eye on the time. this will get you through until you change the timer.
Posted on May 29, 2009
Drum wont turn.pust start and hear a buzz but drun wont turn
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Oct 01, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock mechanism.it might be jammed in the closed position,and should be changed
Feb 06, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Overloaded now wont lock
Try unplugging the washer and letting it sit for a few minutes and then plug it back in.
Oct 01, 2009 | GE WBVH6240F Front Load Washer
I have a two-year old Frigidaire GLTF2940FSO front loader washer that has stopped in the middle of a load leaving water in the drum and will produce a buzzing sound no matter what cycle you put it on. We...
did you try unplugging it and plugging it back in to see if you can get it to reset? Would it buzz when you try to drain it? Does the door latch lock when it goes into the wash cycle? Usually the door latch locks when it goes into the wash cycle and stays locked. So it filled up, the door latch should lock, then should go into wash cycle. Then you said few minutes later it stops. How did you get the door open? reason i ask is Usually i would see the clothes get stuck inside the washer because the door latch is still locked when it stops. Was the door unlocked when it stoped. If so maybe something going on with the communication from the board to the door latch maybe. Did you try operatin the drain?
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
MY AFFINITY WASHER WONT WORK
It is the door lock that may be broken, that's what happened with my maching last summer. The lock is made of plastic if you can imagine. So if you slam the door it can break. A washing machine gets wear and tear how can closing a door be owners fault?
This is a crappy machine in terms of maintenance, it is a maintenance nightmaire!!
Oct 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
Ge Adora front load washer not working
I don't know how you could have got it into diagnostics mode by accident - - but here's how it goes . Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal
Sep 30, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Washer will not start and is making a buzzing sound.
did the belt fall off in the back of the washer. Mine was overlaoded and the belt came off somehow- it went back on fine.
Apr 17, 2008 | GE WSXH208A Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
174 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
