When powered on a black screen with the following message: American Megatrends, The MCH is operating with DDR2 800 DRAM Timing: Tcl:6/Tras:18/Trp:6/Trcd:6/Twr:6/Trfc:52/Twtr:3/Trrd:3/Trtp:3 Initializing Controllers..Done. 6110MB OK USB Device(s): 1 Keyboard, 1 Mouse, 2 Hubs Auto-Detecting Pri Master..IDE Hard Disk Auto-Detecting Sec Master..ATAPI CD ROM Pri Master: ST3750630AS Ultra DMA Mode-5, S.M.A.R.T. Capable and Status BAD Sec Master: PLDS DVD+/-RW DH-16A6S YD11 Ultra DMA Mode-5 Auto-Detecting USB Mass Storage Devices.. 00 USB mass storage devices found and configured. SELF MONITORING SYSTEM has reported that a parameter has exceeded its normal operating range. Dell recommends that you back up your data regularly. A parameter may or may not indicate a potential hard drive problem. Strike F1 to retry boot, F2 for setup utility
Not very helpful info! I would try tapping f12 on booting up which takes you into the Dell Diagnostics mode. Then come back here.
Testimonial: "This is the only screen I am able to view when booting up the regular way or by tapping F12. There are 2 suggestions to try: 1 is tap F1 to retry (it does nothing) or 2 is tap F2 for setup utility (F2 opens up the Bios Setup Utility) I am on the Bios Setup Utility window. How do I proceed?"
Thanks for getting back to me. Sorry it sounds like a major failure on your hard drive. Best thin is to get in touch with DELL Support. Make a note of your Tag number and oDate of purchase and specs of the model, and try to get on to someone els computer.
Add a Comment go to
http://www.dell.com/support/my-support/u... They do an online check but I doubt you can get your machine to do that.
SOURCE: can't access hard drive getting IDE master hard drive SMS mess
You are getting a SMART error indicating that the hard disk drive is/has failing/failed. Likely, the only way to get data off the drive is to send it to a data recovery center, then install a new hard drive. Data recovery is generally expensive, but if you are interested you can contact places like DRIVESAVERS 800.440.1904
