I'm fixing all the faulty phones at my place of employment. Most are power supply issues fixed with a capacitor replacement. But I have a number of phones that either key bounce or don't register a key press partiularly on the 2, 3, 5 & 6 keys. Any ideas on how to fix this will be greatly appreciated
SOURCE: Voicemail isnt set up on phone Avaya 5410
You need to talk to the system administrator. They control the Voicemail.
SOURCE: Cordless phone keypad problem
I too have similiar problem with Uniden phone. In my case it is only the center toggle. I indeed took the phone apart and this problem relates to the metal oxide wearing off the rubber keys that make contact with the exposed circuit lines. This same problem is common with TV remotes. Sometimes you can take apart device and find that cleaning the circuit with rubber eraser can help the problem. You can clean the rubber contacts, but be delicate as you do not want to remove the coating on the key. As far as taking phone apart? Well it helps to be a tech with experience. Usually there is at least one screw or two to remove in the battery area. Then you gently pry the phone apart. Sometimes devices like this slide apart after the screws are removed. If you pry start at position nearest where screws join parts together and work your way up. You may dent the plastic a bit in process. Once you have two halves apart be careful in next steps. There will be numerous screws holding the phone to face. Also be careful of wires to speaker. They are usually hardwired. No plug. As you take apart take careful note of how wires are routed. Also be careful of charge contacts that slide into base of phone.
I could fix my phone if I could get the part, but I suspect Uniden will not sell me the part and ask me to send phone in.
Spinman
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
SOURCE: For the Avaya Euro 18D how do you fix the clock?
http://dstech1.com/changing-time-on-a-partner/
Here you go.
SOURCE: partner-18D (lucent avaya phone)on the display it
Get yourself 2 alkaline AA batteries, keep the power on, and look for the door on the lower part of the face on the ACS processor module. Pop the cover and replace the batteries.
Carl
