Wont charge or turn on, if it does, screen has lines through it
Was purchased 11-20-08, it worked for 3 months. First it wouldn't stay charged, then it would only turn on if plugged in, then screen was full of lines, now it won't do anything.
I have an iphone 4 that i just fixed. it was working fine. i charged it and went to bed and when i woke up there was a blue line going vertically across the screen! help!
I had the same problem and eventually my phone just wouldn't charge at all. I took an old tooth brush n was cleanin the charging port with it then id blow it out n repeat and honestly after bout a half hour of doing this it is now finally charging.
This problem needs to be solved by an expert. The system needs to be reflowed, which involves taking the system completely apart and reflowing the CPU and GPU chips. Sony charges $150 and most refurbish-ers on e-bay charge $60-$100 I Charge $40 and give a 3 month warranty you can contact me via e-mail @ [email protected] just put PS3 problem in the subject line
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
same thing to me but not off ebay when i first bought my 7100t all it would do was show an hourglass but i never used it for a month then i charged it then it worked fine
heres what i would say. let it charge for more than hr, and this bring it up to speed..if not i believe the battery may be defective, i just experienced this problem last night..the battery happen to be defective, then put another battery after awhile i went to sleep woke up, and it wouldn start...i let it charge for a while and it was good as new
When you power up first let it going into off chargeing mode, then hold the power button to turn it on, continue to hold it through this whole process, then after the sitck together box has been completed (which may take a few attempets) rapidly push the right soft key until your phone jump in and out of the t-zones area which should be your default right soft key buttong then you should be able to use your phobe normally, note that it did take me a good half an hour of doing this to make my phone through the whole process. :)
