Electrical Supplies Logo
D
David Grant Posted on Feb 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PIR switches and house wiring is incompatable?
I succeeded in getting one of these switches to work in a hall light with conventional wiring. However, two other ceiling lights are different. One has just black and white wire coming into the box to a single pole switch. The other is part of a three way switch in a separate area. Now, it works just fine in both locations, but in the single pole switch the light does not work at all. The switch is working, you can hear it and see the led working, but it just leaves the light off. In the three way switch area it works even better, except it has a steady flicker. Any tricks or secrets to getting either of these scenarios to work, or am I just wasting my time and should maybe shop for more compatible switches?? My PIR switches have a black, a red, a white and a green wire. And the switches do work for cfl lights.
Gil Shultz
Level 3:
  • Master 3,464 Answers
  • Posted on Apr 29, 2014
Gil Shultz
Master
Level 3:
Answers
3464
Questions
Helped
730757
Points
11104
Several possibilities. First use standard light bulbs until it is working. Some of the PIR have triac outputs which need a minimum amount of current to work. CFL and LED lights can be a problem with electronic switches/dimmers.
The PIR needs electricity to operate. The black and white wire are probably power and return, there is no neutral to connect to the PIR. Unless you can get a different PIR that does not need line power to operate you are out of luck. There may be some that can cycle steal power and would work but I am not familiar with them.
I assume the three way is a three way PIR and the lights that are flickering are electronic such as LED or CFL.
If you talk to one of the people where you bought the switch they may help you free of charge.
Good Luck
5 Related Answers
Anonymous
  • 76 Answers
  • Posted on Jun 27, 2009
SOURCE: need to know wiring diagram for cooper single pole lighted switch
well lets see on one side you should have two brass screws that would be to interupt your lead to the fixture then you either have a brass and silver screws on the other side or you have black and white wires the black or brass is always hot the silver or white is neutral does that answer your question if not hit me back with a description of what your switch looks like
A Miller
  • 8404 Answers
  • Posted on Oct 18, 2009
SOURCE: I have a live 2-wire line that used to be
As I understand it you have a live circuit going to a light fixture that had a switch built into it. You have removed the fixture and now you want to run this wire to another location and install a switch in the circuit.
You will be extinding these two wires (white and black + ground) to the new location. No problem ... Somewhere between where you start and where you finish, you will break the black wire and install a single pole switch. All connecctions must happen inside a electrical box.
So, install the new wire in the box where you will start your extension. Run to the new switch box. You dont even have to cut the white wire. You will wrap the green or ground around the ground screw on the switch, Cut the black wire . put one end under one side screw, put the other end under the other side screw. From this box run your wire to the next box where you will install your fixture.
If you are using metal boxes, they must be grounded to the circuit. You can use pig tails for this, Best deal is to use plastic boxes that dont require grounding.
I hope this answers your question
Anonymous
  • 843 Answers
  • Posted on May 17, 2010
SOURCE: Three way switch does not work properly
Very interesting problem! But easy to fix. It's not a defective switch, just a minor wiring error, which would be very hard to solve via back and forth text. So, instead of trying to figure out exactly which wires and terminals to swap at the new switch, it would be much easier to simply swap the light and fan wires at the ceiling fixture, I hope this is helpful. Good luck, Al Kupchella
Anonymous
  • 351 Answers
  • Posted on May 25, 2010
SOURCE: Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
Testimonial: "I appreciate the response, which reinforced my thought process and it worked - Thanks!"
A
Anonymous
  • Posted on Nov 17, 2010
SOURCE: I have a Cooper Triple Single Pole Switch. I want
The information is a bit sketchy, and you can add a comment with more information.
1) You have a triple switch with dark screw
(s) on one side of device.
You know that Hot attaches to dark screw.
On opposite side of switch are 3 screws.
1 screw is for wire going to bath fan.
1 screw is for wire going to bath light.
1 screw is for wire going to separate light above mirror.
If you do not have a separate wire running to each Load, then you need to add a wire.
2) If I understand correctly, your wall box contains several cables
Each cable has a black and white wire.
Ground wires are twisted together and connected to green screw, and are not discussed.
3) Cable1 black and white are Hot and Neutral from breaker box.
Are you sure?
Test each wire in box to bare ground to find hot wire.
Test hot wire to each wire to find neutral wire.
If power comes from junction box on ceiling, wall box might not have neutral wire.
If neutral wire was used to complete circuits for previous switch, then it is used the same for new switch. That's where the information is sketchy.
You have 4 white wires
1 white goes to each load
1 white is neutral
Where are the black wires associated with these white wires?
Add a comment and say how many cables and where each wire was connected before.
Here's how to start.
Connect Hot to dark screw.
One at a time, connect each white to screw on other side of switch.
Turn on power and flip the switch.
If load turns ON, then that wire is correct.
If load does not turn ON, then leave switch ON. Test each of the other white wires to bare ground to see if this wire should connect to neutral. Then connect that wire to neutral and test switch again.
How to wire slave pir to a master unit touch swtich on a stairwell with two-way switches
sounds like two way switching , 2 switches wired parrell 1 to 1 2to 2 3 to 3
power 2 and 3 , but seek professional advice if using mains
Pir connected to 3 bulkhead lights the lights work but the pir doesn't appear to operate the lights just stay on I have attached a picture of the wiring can anybody tell me if it is correct
It appears you do not have it wired correctly. If you want help a better description is needed. I would think the brown wire needs to be connected to something.
I want to replance a standard wall switch (2 wires: white & black) with a PIR Occupancy Sensor switch
Copy following link for simple walk-thru how to wire occupancy switch
http://waterheatertimer.org/How-to-wire-occupancy-switch.html
This device is made to replace single-pole switch.
Power to fan: note the horsepower range for device: for example if occupancy switch is rated 1/4 Hp, then it will work for ordinary bath fan. If device is rated for 1/3-1/2 Hp then it is rated for whole-house fan.
Each fan motor will have rating plate showing Hp. Check rating labels for each device.
http://waterheatertimer.org/Color-codewire.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Wiring diagram for a p i r to a light
They all wire the same. The black wire on the PIR connects to the incoming (usually black) hot or switched wire. The red wire on the PIR connects to the light(s), usually a black wire. The white (neutral) wire from the PIR connects to BOTH the incoming white wire and the white wire that goes to the light(s).
Jan 17, 2012 • Home
Wiring Diagram for Outside Security Light with PIR
what kind of lights?
most have black, white and green wiring, black to house power, white to neutral, and green to ground
Sep 15, 2011 • Home
How to wire
This should replace any existing single pole (one location) switch. You have two wires on the pir, black and blue and then the ground. The black hooks to the hot or common wire. It may be black, but it will be the hot wire. The blue wire hooks to the wire going to the light. The ground hooks to the green or bare.
I have installed (or tried to) three different Leviton PR 180s in my front hall. All operated the 23 watt fluorescent bulb in the fixture satisfactorily, but were not affected by the ambient light; that...
The Leviton PR180 is a motion detector, or occupancy detector.
It senses infrared heat from a person's body.
I am looking at the manual from Leviton.
Maybe this will help:
There is a small adjustment screw under the wallplate where you can adjust light sensitivity.
Use fingernail or small screwdriver.
Turn control towards the "-" sign and lights will turn on in 'less lighting conditions'
I will be here for a few more hours.
Add a comment and I will help further is needed
Light in one sections will not go on with the switches (2) at both ends of the hall, but all house on lights the hall but all off will not turn off the lights. also cutting power and turning it back on...
I answer questions for free.
I know electric wiring and can help.
But you need a better explanation.
What are you doing?
Did you replace something.
What device did you put in?
Is this a 3-way device at one end of a hall?
And I'm a little unclear about " all house lights on light the hall but all off will not turn off the lights'
If you add a comment I will answer
2helpful
I attempted to install a slide dimmer yesterday. when i pulled the existing switch off I had three black wires (two pushed in to the back of the switch and one wound around a screw) and one white wire...
The white and the black wires are both hot wires, and the green wire is for earth ground only. The green wire does not belong hooked up to the white wire.
The two black field wires should be attached to one side of the dimmer switch (one of the black wires from the dimmer switch)
The white field wire should be attached to the other side of the dimmer switch (the other black wire from the dimmer switch)
The green wire from the dimmer switch should be hooked up to earth ground only (any un-insulated copper wire that is inside the switch/outlet housing) and if you can not find it attach the green wire to the inside of the light switch outlet housing and be sure that it is attached to metal.
The other hall light switch that you are talking about must be connected inline with that light switch you trying to turn into a dimmer, and it should operate again nomally once you have connected that light switch properly, and if not check for any tripped circuit breakers.
Im trying to fix a security light and have wired it into the house and am now stuck at a two way switch in my hall!i've bought a triple two way switch so i can isolate the outside security light the other...
if you only intend to turn the security light of and on just use a single switch fed from the hot (not switched) side of one of the other switches if this is not what you are wanting email me a detailed description of what you are trying to do at [email protected] and i will help the best i can
Top Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
