Heating & Cooling Logo
L
Lyrae Tyler Posted on Feb 23, 2014
F1 warning on heating pad
F1 warning. Won't heat up
2 Related Answers
Anonymous
  • Posted on Dec 02, 2009
SOURCE: f1 error on heating pad
Unplug & then plug in... will help for a little while, but the F1 will return. Sorry.
Anonymous
  • Posted on Mar 29, 2012
SOURCE: Have heating pad model 809.
We have so many of these pads (now only) after the control part went to F1 and F2. My husband found the problem by taking the controler apart. Sadly what Sunbeam does is "pot" the wires. Meaning they put them into some plastic stuff to keep them from touching. But by doing this they leave the wire that makes the thing work to be the weak link that gets weakened even more by use and moving and adjusting the thing. It eventually breaks and he found there is no easy way to solder it back to the "potted" wires. It just leaves a short stub out of the pot. So if anyone knows how to purchase just the cord or fix it the heat pad would probably work just fine. So now we know what F1 and F2 actually means.
Electric blanket won't heat
Take the help of your mattress pad company or look into instruction manual. Do not operate it unless you are familiar with it. You should call the customer care to know how to operate.
Jack from Coriumdirect Mattress pads
F1L error No heat in either oven.
An F1 code indicates a problem with the touch pad or membrane. Replace the touch pad or membrane. F1 can also indicate an issue with the oven's on-board watchdog system, which requires replacing the touch pad or clock assembly.
Jun 29, 2011 • Ovens
1helpful
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I have a maytag MER6772 Gemini Electric Rage it gave the F1-2 code. What must I do to Fix This Problem?
Oven Fault Codes
7helpful
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Oven Fault Codes
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 • Ovens
6helpful
2answers
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
1helpful
2answers
F1 error on heating pad
F1 Error on Maytag Electric Oven
Found something on the net that said it may be a heat sensor so I returned my new touch pad ($220) and put in my old one that was giving me the F1error. I bought a heat sensor ($55) and crossed my fingers. It WORKED! F1 was no longer flashing and the oven's back up and running.. so much for the error codes.. F1 = touch pad and F4 was supposed to be the sensor..
If you're fixing it yourself and think it may be the touch pad, I recommend going through SEARS. Even though the touch pad was an electrical part they still allowed me to return it hassle free and most companies wont accept returns if it wasn't installed by one of their service professionals. So I was more than happy to get the $220 back when it turned out to be the heat sensor. Only downfall is that I had to wait 2 weeks to get the part. Hope this helps anyone with the same error.
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
Top Sunbeam Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
