Hitachi CP-S335 Multimedia Projector Logo
Posted on Jun 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hitachi projectors cp rx60 cp r555 same remote control?
I can get a remote for a hitachi cp rx60 projector - i wanted to know if it will operate a hitachi cp r555projector?
Anonymous
Level 2:
Champion:
  • Expert 205 Answers
  • Posted on Jul 07, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
205
Questions
0
Helped
73580
Points
412
Specifically i don't know. What i do know is mfg's use the same codes, whether they map them to the same functions across a series of remotes can't say for sure. Experiance tells me it will be just fine...
Hitachi cp-rx60 not powering Temp led light blinking red non stop what could be the problem
you should clear the air filter
and reset the air filter timer
menu-advance-option-reset the air filter
I Supply the Projector accessories,in China.
projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price.
WhatsApp ID:+8613178867858
Skype:[email protected]
Wechat ID:+8613178867858
Email:[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
1helpful
Hitachi cp-s240 remote question
Hitachi data projectors are able to function as a mouse using either the USB port or the control port located on the back of the projector.
However, they are not intended to be used as a remote presenter. This means that although you can use the remote as a mouse, you will not be able to change slides in a full screen slide show using powerpoint.
I recommend the Targus remote presenter for this purpose. This device will function as a mouse, pointing device, and will allow you to change slides in powerpoint. In addition, it's inexpensive, wireless, and small enough to easily fit in your pocket.
4helpful
2answers
Cleaning the filter/blinking LAMP and TEMP
Goto Advanced menu and select option then lamp Time hold down the reset button on the unit for 3 seconds until a new screen comes up then hit reset. Do the same for resetting the filter time
Not displaying on laptop
Have you tried pressing the Fn key in combination with the Monitor key (F4 or F7, varies by laptop)?
14helpful
2answers
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
2helpful
Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
3helpful
Reset
Hi there
Check if both your filter timer and lamp timer is reset.
If it is then there is a Mainboard fault and it will need repair or replacement.
Hitachi CP-L850W lamp reset (No Remote)
easy on botem vent unscrew it then u see screw in ther holding balest of the bulb unscrew it litte pull up action on its arm as u will see lift it all out to get new in then reset timer ok
53helpful
7answers
Hiya there, just worked out how to reset the filter timer so for those that need to know here's the solution;
Bring up the menu and go right the way down to "Option" where it shows you the lamp and filter hours.
Next highlight/select the filter timer section and while its on there hold the RESET button on the remote for 5 seconds.. this then pops up with a resert option and hey, 0h again, good as new! :-)
Oh and if you dont have a remote, just hold the right arrow button instead for 5 seconds in place of the reset and follow instructions as above!
Hope this helps.
Regards,
Omar.
Top Hitachi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
