Pride Jazzy Select 6 Indoor Power Wheelchair Logo
R
Rick Jones Posted on Feb 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Noise in gear box troubleshoot jazzy scooter
Making noiseGear box
wcdoc1953
Level 2:
  • Expert 280 Answers
  • Posted on Mar 06, 2014
wcdoc1953
Expert
Level 2:
Answers
280
Questions
0
Helped
129651
Points
552
Gearbox noise is a good indicator that the gearbox is getting ready to fail. The best solution is to replace the motor and gearbox. If you don't have insurance they can be rebuilt for some cost savings.
Where is the fuse on my Jazzy pride mobility scooter
the fuse box location may vary depending on the model of the scooter. However, it is usually located under the seat of the Jazzy scooter. You can access it by unscrewing the two bolts that hold the seat in place. Once you remove the seat, you should see a black box with a white label that says "FUSE". The fuse is located inside this box.
Model 888SI+10 pihisang mobility scooter rear controler box diagram
I'm making over $7k a month working component time. I saved hearing other people inform me how much cash they could make online so I decided to look at it. Well, it turned into all proper and has definitely modified my life. This is what I do...www.cash.hiring9.com
Jazzy 600 powewr chair intermittion operation
The small click noise is the parking brake releasing to allow you to drive. the flashing is called a flash code that will give you an idea of what is wrong. count the amount of lights flashing this would indicate the problem. Post the amount of lights flashing and some could give you the meaning of the code.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
What is the torque specification for the drive shaft to wheel hub nut on my mom's Jazzy?
Hi this happens with a lot of scooters u could try some LOCKTIGHT unsrew the nuts put the locktight on & tighten them up I use a 2 foot socket bar to tighten them ....good luck
Have a jazzy elite bought it for $ 200 new has been making a pronounced clicking noise while in operation
hi tighten the centre wheel nuts if they r loose they will make a clicking noise hope this helps
My jazzy blinks 7 time what does that mean?
Possible Joystick Trip
A joystick trip is indicated. Make sure that the joystick is in the center position before switching on the Pilot.
May need a trip to a service centre to plug the diagnostic box in to check for errors.
My rascal scooter was making a wining noise now it wont go
Hi, Firstly disconnect the batteries and let the scooter dry out,
1. Does the scooter now turn on ? once batteries have been reconnected.
2. The wining noise was coming from the rear ?, if so firstly check the wheels are okay can be turned around, now the noise was most likely coming from the motor or gearbox, can it turned round in free-wheel okay , this will prove that the gear is not jammed etc...
Please update me on the situation.
Regards
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
