New Home MX-3123 Computerized Sewing Machine Logo
A
Anonymous Posted on Feb 23, 2014
Mx3123 user manuel - New Home MX-3123 Computerized Sewing Machine
Hi. I am looking to buy a sewing machine. Not sure what to buy. Between Janome MYEXCEL 23X/MX3123 and brother XL 5011 any suggestions?
Even the best of machines vary depending on how they are being used. Certain machines are better at embroidery, while others are better for sewing garments or home projects. Decide what you want to do with your machine, test them out, and then decided which is best for YOU!!!
Mx3123
Mostly it happens when tensioner is to tight. Try letting off tension a little at the time.
2answers
Where to oil Janome mx3123
you can contact janome customer service & ask them about the
oiling or I've providing a link for a manual to see if the oiling information
is in the manual
http://www.sew4less.com/product/560/Janome_and_New_Home_MX3123_Instruction_Manual
1helpful
Janome New Home mx3123 reverse button not working
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work!
Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Top New Home Sewing Machines Experts
NOEL
NOEL
Paul Bade
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
