Life Fitness 9500RHR Dove Tail Recumbent bike Logo
D
Derek Shugart Posted on Feb 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery Though being used regularly, the battery was dead when I went to use the bike. A new battery was purchased from National Gym Supply, but after about a month of regular use, it went dead, too. It seemed like the control panel was staying on for a while after use. Do you think it may be the control panel, the alternator, or something else that could be draining the battery?
Sportsmith LLC
Level 3:
  • Life Fitness Master 920 Answers
  • Posted on Jun 04, 2015
Sportsmith LLC
Life Fitness Master
Level 3:
Answers
920
Questions
0
Helped
514221
Points
111994
Possible causes for a dead battery or battery that doesn't hold charge
1. Battery has lost its ability to hold a charge, (dead battery)
2. Charging system on unit has failed (battery cables, alternator, or alternator control board)
3. Stuck key on the display is causing a constant draw from the battery.
We recommend to visually inspect your machine to make sure no wires are damaged or loose also.
If this does not solve your problem or you have further questions please do not hesitate to contact us online or by phone,
888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
Battery 9500hr
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
If the battery continues to fail, I would check the alternator brushes and see if they need to be replaced. Chances are they are worn and the battery is not being recharged sufficiently.
Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
Www kodak com go support
You may use regular alkaline batteries, though they won't last as long as lithiums. You should be able to buy the batteries at just about any department, electronics, or office-supply store. Your local supermarket will also probably have alkalines, though they tend to charge more for such stuff than a department store.
Jan 22, 2014 • Cameras
Battery won't hold it's charge when fitted to the bike even though it charges when bike is running?
You have a drain of power somewhere. Check all the earths that you can reach. Do you have a dodgy alarm that may have water in the connections, or a damp ignition switch. Use some WD40 to obtain better contacts.
Hello, have a 2003 XL 1200 custom that wont start,what is happening when you kick it over and it starts clickin then starts to die away like battery going dead. cheers Jes
I think you hit the nail on the head, Jes. Sounds exactly like your battery is going dead. Just to make sure, take the battery out of your bike and take it to an automotive parts store. Have them test the battery. They'll usually do this free of charge. If your battery is over two years old, it's probably bad.
Now, if you purchase a new battery, get the highest CCA (cold cranking amps) battery you can get. Also, consider the purchase of a Battery Tender or a Smart Charger that will connect directly to your battery via a short pigtail. Do not use a regular automotive battery charger. Put the pigtail on your battery and when you get of the bike, plug the charger to the battery. This will increase your battery life tremendously.
Good Luck
Steve
9helpful
I also have a lifefitness recumbent 9500RHR. The display panel wont light up on pedalling. There was no 9V battery in it!! When I take off the cover is the rechargeable battery the blue round thing on the...
That component is a capacitor and not a battery, The battery is locate on the back portion of the bike frame, tilt the bike to its side you'll notice a plate remove the 4 screws flip the plate over. On that plate is the battery it has 2 leads red ( + ) and black ( - ) leave them on until you purchase the new battery. After receiving the Battery their is 2 screw that attach the battery to the plate and replace with new battery reverse procedure to install.
You may purchase this item from National Gym Supply Part # LC001.5 cost $19.80 tax and s/h Call them @ 1-800-496-7278
1helpful
2answers
Machine has not been used in a long timescreen is flashing is battery dead? how do i charge battery?
You may get a battery charger for National Gym Supply, If that battery has been in that unit for a good length of time I suggest replacing it. Here is their Ph# 1-800-496-7278
1helpful
No power on my Precor C846 reclined cycling machine
Was the on/off switch left on? if so then what happen it drain the battery in some cases depending on the age of the battery you may be abel to pedal for about 5 minutes doing this may charge the battery. If this did not work replacing the battery is the next step Call National Gym Supply @ 1-800 496-7278 Batt part # is PRX12258-070 cost 64.20
5helpful
Our life fitness 9500hr recumbent bike stopped working
If this unit has not been used for that period of time then the 6v batt has died ans needs replacing call National Gym Parts @ 1-800-496-7278 to order part# LC001.5
HERE IS THE PROCEDURE TO REPLACE THE BATT:
Tilt the bike on its side, remove mounting screws securing the battery to the bracket. Remove the battery just enough to access and disconnect the black (neg) wire from the (-) terminal and the red (pos) wire form the (+) terminal. Replace battery and reverse procedure when installing battery
Replacing the drive belt
YOU CAN PURCHASE AN MANUAL FOR ABOUT $20.00 TO $25.00 PLUS S/H FROM THESE PEOPLE : NATIONAL GYM SUPPLY 1-800-496-7278 THEY WILL NEED M# AND SERIAL#
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
