Unit works fine other than yellow discoloration from popcorn catching fire. Door doesn't always latch properly
Door catches.
One of the latches may be damaged or
misaligned and is not lifting the other latch clear of the housing.
Remove from any power source, remove the cover of the cabinet.
Slacken off the clamp mechanism and ease the clamp over the guide to
allow the door to open. When the door levers are in place, the door
may be easily adjusted by slackening off the screws that clamp the
door catch/actuators in place whilst holding the door closed and then
tightening the screws. The rear of the door may be adjusted by
slackening the lower door hinge screws and adjusting as required.
I
hope that helps.
Door switches
If one of the door interlock switches
is not switching properly or there is a condensation problem on the
sensor control panel, either can cause the turntable/light/oven to
come on even though the "Start" button has not been
depressed due to the wiring of the switches.
Check for faulty door
switches and/or contaminated actuators.
I hope that helps.
Door catches.
I
hope that helps.
Door catches.
Door switches
I hope that helps.
Door catches.
One of the latches may have been damaged or is misaligned
and is not lifting the other latch clear of the housing. Remove from
any power source, remove the cover of the cabinet. Slacken off the
clamp mechanism and ease the clamp over the guide to allow the door
to open. When a new door lever is in place, the door may be easily
adjusted by slackening off the screws that clamp the door
I
hope that helps.
