Cisco ASA 5510 Firewall Logo
Posted on Jun 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to configure static route between 2 LANs?
How to configure static route between 2 LANs? I have LAN1 with IP 192.168.10.0 and LAN2 with 10.200.14.0 I need static route to LAN2 with gateway on 192.168.10.2
i tried this command:
! configure an internal static route to reach network LAN2
ASA(config)# route inside 10.200.14.0 255.255.255.0 192.168.10.2
didn't work for me.. Please Advise.
  • alazarev Jun 25, 2009
    config is pretty standard as i didn't change anything else.
    I think I'll just place router in front of this 2 gateways to rout traffic.
Gopi Venkatesan
Level 2:
  • Expert 74 Answers
  • Posted on Jun 11, 2009
Gopi Venkatesan
Expert
Level 2:
Answers
74
Questions
0
Helped
55221
Points
115
The command what you have given is correct as per your explanation. If you could post the configuration, it will be good to fix the issue.
Anonymous
Level 1:
  • Contributor 39 Answers
  • Posted on Jan 24, 2010
Anonymous
Contributor
Level 1:
Answers
39
Questions
Helped
13602
Points
63
Agreeing with kvgopi, we really need to see the config
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jun 25, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
2497
Points
15
Do you have another router involved besides the ASA? What is the inside/outside address of the ASA?
Does the Configuration of an Active Static Route Still Exist When the Outbound Interface Status of the Static Route Goes Down?
If the outbound interface state of a static route goes Down, the static route will be deleted from the IP routing table, but its configuration still exists.
http://www.thunder-link.com/LS-S6700-24-EI_p785.html
Router modem-CAT5 adaptor
does this router have a lan1 lan2 lan3 lan4 ports ?
the adsl port may be for a phone line so you may need to turn off the ADSL functions in the Huawei Echolife HG520s router . Turn off the DHCP server and then plug connect lan1 to your office network. Change the ip address to be unique in your office network ip network range.
maybe 192.168.0.2 if office router is 192.168.0.1 subnet mask made the same .
2answers
TL-PS110U. Can't find my print server
Type IP address (ex. 192.168.0.10) directly into your browser...should identify it and give you some direction on the problem..
Connection error
can you clarify the switch configuration, by default it will have all ports as untagged in the default vlan 1 with a bootp/dhcp address, I assume you will need to perform some kind of routing ie; default gateway, ip-helper address or static route to point to your routing device ADSL router etc try the following;
1~ configure an ip helper address on vlan 1 to point to what ever is supplying dhcp
2~ create a defualt route on the switch ie; 0.0.0.0 0.0.0.0 to next hop / routing device
3~ configure a default gateway ie; ip default-gateway x.x.x.x where x= routing device
the above can be accomplished via a serial connection to the switch using hyperterminal with the following settings
bits per second 9600
data bits 8
parity none
stop bits 1
flow control none
let me know if this resolves the issue
Routing problem
I don't know if this will help because I don't see what you and seeing but here is an idea: In every routing scenario I have experienced, you must specify a default gateway with a specific IP address. 0.0.0.0 only points to the device itself, not the other WANS. The gateway IP addresses should be statically assigned. If there is DHCP involved, insure that the gateway address is not part of the DHCP scope but in an excluded range of reserved addresses. For SMTP to work the gateways (and you should have 2 or 3) must be properly configured and TCP port 25 enabled.
2answers
My Nas Fastora T4
There's a 9-pin serial connection on the back, can you use that connection to a terminal to see anything? Also, if you don't have access to the manual, visit this link to download the manuals: http://www.fastora.com/product_index.php?doc_name=nas-t4
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
