SOURCE: 2002 BMW 325 - key locked in trunk
There are several suggestions out there on how to retrieve BMW keys from the trunk. Many of the ways I tried failed, and it takes 2 to 3 days to get a new key made up. In the coupe there is the center piece in the back seat that folds down. Then on the back wall there is material that will fold down that is held up with Velcro. Behind that you will find a rubber insulation that is mostly cut and looks like a door, but not all the way. Carefully cut the rubber to remove the piece. Now you will find a metal wall, but there is a large piece that is tack welded on. I got turned around and kicked it with the bottom of my foot and got 3 sides loose. Then a softball bat knocked the final side loose. Pull that out and trash it, the final barrier is the insulation that is held in place with plastic clips that can just be pushed down. After that you can a pretty large hole to work through and get the keys. Just put everything back in place other than the metal plate and you will never know anything was done.
SOURCE: How do you reset the Service light on 2006 BMW 325
Hi , to reset the service light you will need to insert the key and turn the ignition lights on but do not start the engine. you will see a push button on the lower left side of the instrument panel press and hold this until you have a triangle appear which then turns to the brake warning symbol , release the push button then press and hold the bc button in the indicator arm until reset appears , release and again press and hold the bc button until you have a moving clock symbol appear , release the bc button and wait for the display to change , once this has reset turn off the ignition and the service symbol should have reset . you may want to print these instructions before resetting , regards Mark.
SOURCE: Where can I find a fuse box diagram for a 2006 BMW
Check this...
Link HERE
Hope this help you.
SOURCE: 2006 325i bmw fuse box diagram and where is it
Check this out... this may help http://www.e90post.com/forums/showthread.php?t=375396
Sorry if this wasn't exactly what you were looking for.
