The power light is blinking. Tried to reset according to HP support, didn't work. When I connect to power again, blinking light appears and am unable to turn the TV on.
SOURCE: unable to start laptop
I understand the urgency and also the importance of data stored in the laptop.
As the laptop is unable to start in normal mode let us try in safe mode.
Follow the steps below:
1. Turn the laptop off completely.
2. Press the power on button to turn it on and at the same time simultaneously keep tapping ' F8 ' key on key pad until you see a advanced boot options screen.
3. Select 'safe mode' and hit enter.
Thank you.
SOURCE: HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
SOURCE: hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
SOURCE: Power and attenion keeps flashing says turn power off then on
Perform a partial reset of the HP All-in-One
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: green light blinks continuously, printer will not
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
