I've removed the back and there are no paper jams and none in front. Tried re-installing cartridges (left color first, then right b/w) twice. Insured paper guides are in farthest positions. Left 2 sheets of paper in tray. Powered off and on twice.
As the cradle moves left to right and right to left, makes clunking sound. This is a home printer and lightly used. Any suggestions?
SOURCE: HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
SOURCE: will not print / cartridges will not move back and forth
I had this happen to me the other night and I had to restart the printer to get the print job out of the que. You could try that.
While it's restarting, unplug the power cord and the usb cable. That should reset it.
SOURCE: HP PSC 1510 PRINTER
first ckeck out the your cartages are ok and then when you start the printer them it print the alignment page then put it in the scanner and scan it your problem will be surually solved
SOURCE: HP PSC 1510 All-in-One Printer/Scanner/Copier, how do you stop the sheet it prints out at start up.
How do you stop the HP PSC 1510 All-in-One from printing a test sheet every time you turn it on?
