Ge washer motor
You ;listed it as an Amana, but said it is a GE. I will give you direcions for a GE. If its not, let me know. First, be sure the unit is unplugged and water line is off. Underneith the motor, down right above the belt, you will see 4 nuts that hold the motor to the mounting plate. Remove these nuts, then slide the belt off. Lift the motor slightly, then aim the top of the motor back towards the middle of the unit. Keep tilting and moving the motor backwards until the clutch clears the mounting plate. Slide the motor now towards you and remove. Replace motor following any new instructions that come in the package. Good luck, and let me know if you need further instructions.
