Gateway 6920 the hard drive died after two years were up. It revived mysteriously while I was using it to recharge a friends mp3. died again 2 weeks later. I was told the h d was dead. just got a new one ten days ago and last night I shut it off and the the screen went black but switch indicator light stayed on and this morning it wouldn't turn on (the switch light was still on) took out the battery.. replaced it and it worked. half hour later the screen went black and I couldn't do anything but the internet music still played. did the battery thing again and it has been running for 4 hours no problem. What's goin on?
  • william dean ziemer
    william dean ziemer Feb 21, 2014
    Me again. The first time it died I took it to a couple tecks who said the hd was dead and it was almost a ear later when it kicked in again. that time I was told b three tecks (one a friend int the states who tossed it) "It's fried!" I live in Guatemala.
    Master:
  • 788 Answers
The dying hdd cause some problems. Replace the hdd.
Posted on Feb 28, 2014
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 89 Answers
SOURCE: Toshiba Satellite A60 powers up then off after 2 seconds
Mark F K, truong808, does the cooling fan(s) blow or come on? If not, the system will sense tha ti is overheating and will shut down to prevent further damage. Also, a thermal sensor may be failing on the Mobo and thus keep the fan from initiating. The cheapest fix is to replace the fan. Worst case scenario is another Mobo may be the fix.
Posted on Jan 07, 2008
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: dell latitude D600 display blacks out, showing just a ghost image
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 22, 2009
Anonymous
SOURCE: How long should my Laptop battery last?
if you are running alot of programms and your screan brightness is on full your laptop battery will die fast.
try running one or two programms at a time. this will lenthen your battery time. plus dont leave it charging all the time this will ruin your battery.
Posted on Oct 09, 2009
Acer 6920 missing 2 registry files and can't auto repair or start. Hard drive has only 25 gig space left. Are there some files I can download to repair without wiping the hard drive and starting o
If you have the Vista disk, insert it into the CD Rom player. When it starts it will ask you if you want to repair or install a fresh copy. If you choose repair, it will fix any missing registry files
Jul 28, 2012 | Acer Aspire 6920 Notebook PC
Tip
Tips Phones - MP3 Players to gain autonomy
Your phone or MP3 player or any device Compaq presario cq60 battery is normally technoloogical lithium-polymer. They are useful for about 500 charges. Only 500, you ask? Charing is a cycle where the battery is completely empty. There is no limit to the number of times you can rechagre a capacity of 50%.
If you recharge your Phone, Mp3 Compaq evo n410c battery every two days. 500 charges, on average, should last you almost 3 years.
Here are some tips to increase the lifespan of the Acer Aspire 5000 battery.
  • Do not let the battery die completely.
If you want to get the most from your Dell XPS M1210 battery life. Do not allow the discharge of 100% until she died. However little you use your Phone, reader MP3, recharge once every three weeks to prevent the Apple a1080 battery from going flat. If you go on vacation for a month, you should take your Phone or reader MP3 with you and recharge it.
  • Try reducing the power required.
A car with air con will consume more fuel. A Phone or Mp3 with ligh, when you're in the day will use more energy. On an iPod, this is called "backlight" that can easily be disabled. You do not sound too high. The higher the more energy it uses.
on Oct 11, 2010 | Computers & Internet
I bought this model, and a year and a week later the drive crashed. After arguing, Gateway replaced the HD. One year later, it crashed again. I was getting BlueScreen Of Death dumps each turnoff. ...
Try reinstalling vista again first to avoid another drive. Could be just a conflicting driver issue or deleted dll or something altered by a program or malware/virus and even virus protectors do their job too well and remove certain files that maybe a virus was attached to.
May 08, 2011 | Gateway DX4720-03 PC Desktop
1993 buick lesabre shut off while driving,battery was dead then bought a new battery drove well for 3 weeks then shut off while driving again had to jumpstart it.
Your alternator is bad. It's not recharging the battery as you are driving. The car is using battery voltage until it is all used up and then the engine dies. Replace the alternator and recharge the battery.
Jan 04, 2011 | 1993 Buick LeSabre
Bad motherboard or power supply which fries motherboard
Gateway hasn't had any recalls on it that I know of. maybe it is not the mother board. It might be the hard drive. Hard drives can do that aswell. When I fix a computer the first thing I check is the hard drive. A little bit of advice with computers. Start with the small things first and work Your way up to the big stuff. Hope that helps.
May 20, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
2000 s10 Blazer dies very 3-6 weeks for no reason
i would check your ignition system. you would need a meter for this but look for broke or loose connections. if it was a fuel problem i dont think it would just start up after 20 minutes. or you might try your ignition switch. if its shorting or something then ya well it would cut your engine off real quick
Mar 20, 2009 | 2000 Chevrolet Blazer
Aspire 6920 Operating system not found
you have no choice but to open it up, this is to check that the hard drive works or has disslodged, pull the hard drive out and then reseat it again, reboot the laptop and see if the bios has found the hard drive, if it does try to boot into it
kind regards
Dec 22, 2008 | Acer Aspire 6920 Notebook PC
IRiver H320 is completely dead
you can change battery and/or upgrade hard drive (if changing hard drive, save the software to pc then copy to new hard drive)
how to replace battery / hard drive
check and follow this link http://www.youtube.com/watch?v=6HOnpHSgMvw
if you dont have tools http://www.ipods99.com/Default.asp?Redirected=Y
Sep 18, 2008 | iRiver T20 MP3 Player
Laptop Gateway mx8711
Gateway laptop is really ****.
I bought Gateway MX8711 in March 2007, after 6 months i use it...the hard disk failed.
Gateway replaced a new Hitachi hard disk for me but not more than 8 months and it failed again.
Gateway told me that i have no more warranty because the repair warranty is only 90 days.
I bought this laptop and use it not more than 2 years, the hard disk was failed twice.
Usually Hard disk manufacturer provided 3 years warranty for the hard disk. The manufacturer year of the hard disk is May 2007....they should able to help because the har disk not more than a year being used...but they don't. This is really bad customer service and not fair to the buyer.
I will not buy any Gateway products anymore....i swear.
Jun 24, 2008 | Gateway MX8711 Notebook
Has had 2 different problems
your set needs to be taken to a tech for repairs it is having a micro computer problem.good luck
Apr 02, 2007 | Panasonic DMR-E80H DVD Recorder
Open Questions:
Computers & Internet Logo
50 people viewed this question
Ekse
Marvin
Marvin
