Don't worry, try uninstalling it using uninstall program like "ccleaner". You can easily uninstall it and again reinstall the adobe reader.
If you still have the same problem, use this Foxit reader
as an alternative for the time being if in case, you need to read the pdf file immediately.
Good luck.
Thanks for using FixYa.
U can use system restore to restore it back. What u need to do is run system restore wizard & select a restore point earlier to the un-installation. System restore will fix it for u. U don't need to search for the software anymore.
Download and install this fantastic free program CCleaner. http://www.ccleaner.com/download
During the installation watch for the download of the Yahoo Toolbar and uncheck that box to prevent that from being installed. Now open CCleaner and go to the Tools tab >> Uninstall tab and uninstall Google Chrome. Now go the the Issues tab and scan for issues. Fix all issues it finds and make a backup if you wish, although I have never seen CCleaner cause any problems. It is a mild, safe, registry cleaner and will find many issues if you have not ran a registry cleaner before. Now go to the Cleaner tab and run the cleaner which will remove all temporary internet files and files you no longer need. Close CCleaner and open Disk Cleanup and run that. Remove all it finds. Restart your computer and install Google Chrome again.
Hi there. The reason you get that message is because the uninstaller has become corrupt. You have to manually delete the program from program files on c drive and also from all programs in the start menu. Download and install CCleaner to get rid of any residual files or registry entries from the computer.
Get CCleaner here >>>>>
http://www.filehippo.com/download_ccleaner/
Please post back if you need anymore help or advice.
It sounds like you're SP3 installation is corrupt. Go to start > control panel > add/remove programs > uninstall SP3. See if you can do a restore point then. If so, re-install SP3.
You did not mention if you uninstalled it. Did you? If you did and it is still doing, do what I have done in the past with excellent results. Do a System Restore to a restore point created prior to installing it. I would also suggest using the freeware, CCleaner, which will also clean your registry.
Of course, if you have not uninstalled it, then that would be the thing to do - time to look for something else that works. :)
Do you have a restore point set prior to the offensive software installation? Try going there. I know that Uninstall does not always find everything it should so I have had to delete things manually sometimes. The hard part is finding this stuff to delete. Also check the drivers. Maybe this software installed its own drivers.
go to start menu choose avg and choose uninstall, if this fails try it from controll panel add/remove programs remove avg. if this fails download ccleaner from this link http://www.ccleaner.com/download its free, install it and choose issues do a registry scan follow the instructions and then try to uninstall avg again...
