Broken fuser heater wire (main)
When the fuser thermistor 1 reaches primary stable temperature after a warm-up start and the fuser thermistor 2 is less than 90 ° C/194 °F.
Causes
Fuser unit. Main/Engine PWB. Power source PWB. Fuser heater.
C6000 : Fuser heater break.
Fuser thermistor 1 detected less than
40°C/104°F for 10 s during warm-up and ready in.
Defective fuser heater M or S.
-Replace the fuser heater M or S.
Installation defectiveness on fuser thermistor 1.
-Check the mounting state of the fuser thermistor 1. If any problem is found, repair it.
Defective fuser thermostat.
-Replace the fuser thermostat.
Defective PWB.
-Replace the power source PWB or engine PWB and check for correct operation.
After parts replacement (fusing unit), you need to clear the fuser error code by going in the tech mode (10871087) and then U163.
This Code relates o the fuser unit, needs to be replace but if this code keep coming constantly from time to time than you need to check this: There is a two wire power connector from the switching regulator ( by the interlock switch ) that goes to the fuser connector. This is one of the areas we check for the 6000 error code. You could also check for a small piece of paper lodged in the fuser connector, both on the fuser and the one at the engine board. also Check the power at the wall outket. Low power will cause 6000 errors.
i have 7410 error call service. i tried to clean everithing en replaced the tone is almost full- still getting the error message.hat can i do. (fs-3900dn)
Code: 6000 Contents: Broken fuser heater lamp wire 30 ppm model: The temperature does not rise 1×C after the fuser heater lamp has been turned on continuously 5 s. 35/45 ppm models: The temperature does not rise 1°C after the fuser heater lamp has been turned on continuously 5 s. The temperature does not rise 1°C after the fuser heater lamp has been turned on continuously 10 s during waming-up or at standby.
Causes: - Poor contact in the fuser thermistor M connector terminals. Check procedures/corrective measures: - Reinsert the connector
Causes: - Fuser thermistor M installed incorrectly. Check procedures/corrective measures: - Check and reinstall if necessary
Causes: - Thermal cutout triggered. Check procedures/corrective measures: - Check for continuity. If none, replace the thermal cutout
Causes: - Fuser heater lamp installed incorrectly Check procedures/corrective measures: Check and reinstall if necessary
Causes: - Broken fuser heater lamp wire. Check procedures/corrective measures:: - Check for continuity. If none, replace the fuser heater lamp
6000 simply means Broken fuser heater lamp wire The temperature does not reach 100°C/212°F after the fuser heater lamp has been turned on continuously for 30 s. The temperature does not rise by 1°C/1.8°F after the fuser heater lamp has been turned on continuously for 5 s during printing. 35/37 and 45/47 ppm printers (EUR/USAmodel): Fuser thermistor M detection temperature does not rise by 1°C/1.8°F after the fuser heater lamp has been turned on continuously for 10 s during warm-up or at standby.Fuser thermistor S detection temperature does not rise by 1°C/1.8°F after the fuser heater lamp has been turned on continuously for 5 s during warm-up or at standby. Poor contact in the fuser thermistor M connector terminals.Reinsert the connector (See page P.1-5-19).Fuser thermistor M installed incorrectly. Check and reinstall if necessary (See page P.1-5-19).Thermal cutout triggered.Check for continuity. If none, replace the thermal cutout (See page P.1-5-19). Fuser heater lamp installed incorrectly. Check and reinstall if necessary (See page P.1-5-19).Broken fuser heater lamp wire. Check for continuity. If none, replace the fuser heater lamp (See page P.1-5-15).
Hello, this code is : Fusing temp. warming-up error. This means that the fuser did not warm-up in the allowed time. Possible causing-- in order; Thermistor bad or out of position, fuser lamp bad, thermofuse bad, BICU board defective, power supply board bad, poor fusing unit connection ----check this first if you had the fuser out of the machine.
If you would like to talk, I can see if we can try to reset the code -- sometimes if the machine is to cold at warm-up the code will throw. # 216-701-1591. Thank you.
6000 Broken fuser heater lamp wire
30/31 ppm printer (EUR/USA model):
printing.
model):
printing.
Poor contact in the
fuser thermistor M
Fuser thermistor M
P.1-5-19).
Thermal cutout
triggered.
Fuser heater lamp
P.1-5-19).
Broken fuser
heater lamp wire.
