De Dietrich LZ9619 Front Load Washer / Dryer Logo
A
Anonymous Posted on Feb 20, 2014
Cannot open door on washer dryer - De Dietrich LZ9619 Front Load Washer / Dryer
How do i replace a stack washer dryer dryer door switch?
when you open washer door you hit a stopper pin that holds the door open. there are 2 screws located around that area on both sides of panel. remove them and you'll see vent hook up and water line hook up and power cord. Now at the backside of washer door panel there are two screws remove them and pull washer door panel towards you. under the door panel connected to panel is where you will find door switch. if you jump out door switch and it works then you need new door switch.
2helpful
2answers
Is door reversible on duet model GHW9100LW1
The technician informed that we cannot reverse the door on the washer.
The door on my dryer and washer open the wrong way
On these model you can only reverse the door swing on the dryer but not the washer.
Alternatively, you can switch places with the washer and dryer provided the washer fill and drain hoses are long enough and there is enough room without obstructing the dryer exhaust vent .
If you want to know how to reverse the door swing on the dryer, post your model number and I will try to assist you further.
1helpful
Can you switch the side the doors open and close.
sorry but the washer can not be changed. its strike has a lock and can not be reversed. the dryer can be changed, but the best thing to do is move the units and get some longer hoses for the washer.
hopefully you can switch the position of the units, but if not then you will be doing the laundry dance every time you do wash.
1helpful
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
3answers
Washer Dryer - drum is filled with water even when switched off and door can still open!
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
I want to change the way my doors open on the washer and dryer
washer door can't be reversed on matching dryer best bet buy longer hoses for washer and longer vent and cord for dryer and reverse their locations
Doors
First Read your owners manual and see if the doors are reversible. They may or may not be?
at one installation we did the washer was not reversible so we put the dryer where the washer was and the washer where the dryer was, customer was very Happy and was Happy to pay $$$
Top De Dietrich Washing Machines Experts
john h
Are you a De Dietrich Washing Machine Expert? Answer questions, earn points and help others
