New Air NewAir AI-100S Portable Ice Maker Logo
Russell Dillard Posted on Feb 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My NewAir Portable Ice Maker no longer makes ice. It pumps water up into the resvior but the fan motor never turns on and it does not freeze the water. Why is it acting this way?
Is no longer making ice. Actually, I have a New Air A1-100R, but was not listed under products. It pumps water up into the reservoir but never freeze the ice. Why?
Wayne Lee
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 20, 2017
Wayne Lee
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2494
Points
The fan sensor that looks like a silver bullet shoved in a holder on close to the fan is bad. Cut it and twist wires together and put a wire nut on it. That should do it.
jasbo
Level 3:
  • Master 2,239 Answers
  • Posted on Feb 28, 2014
jasbo
Master
Level 3:
Answers
2239
Questions
Helped
991966
Points
5072
Is the compressor hot? if so, the fan might be dead. the condenser needs air flow to cool down. if the compressor doesn't even turn on, the starter coil (inside the box on the front of the compressor) may be shot.
Have 4 yo Newair under counter ice machine. The ice machine runs through its normal cycle but there is no ice made only cold water is dumped into the ice bin.
According to Newair, the ice maker may be leaking coolant, which requires a "qualified technician" to fix. Check to see if there are any oily substances leaking from the device. Also, the device may be in too warm of an environment (but if it has been working in the past where it is placed now and that environment's conditions haven't changed, I personally don't believe this is the issue). On another note, the water in the reservoir may be too warm, so try filling it with colder water.
http://www.newair.com/articles/how-a-portable-ice-maker-works/
May 18, 2017 • Dishwashers
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Ice maker won't make ice
most times I see the tray and fill tube ice up its due to a leaky fill valve , this valve should close tight after filling tray , but sometimes they leak just slightly then everything freezes up in a block of ice
fill valves on most all units is located in back lower left corner , just follow the water line in the back of unit
Whats wrong with it?
sounds like something isnt clipped in properly or it isnt sensing that the water is in the reservoir
No loger makes Ice, Fan Motor does not seem to be working. How can I check it?
use a volt meter and see if there is power to the fan. if so, replace the fan. if not, the board is bad
1helpful
Ice machince is going max freeze cycle shut down
1. Possible cause. Water leak. Check purge valve, water curtain, sump, sump hose.
2. Air filters clogged. Clean air filters.
3. Dirty condenser. Clean condenser.
4. Restricted location, intake air to hot. Have machine moved.
5. Ice thickness sensor dirty or disconnected. Check ice thickness sensor probe.
6. Water distributor dirty. Remove and clean water distributor.
7. Inlet water valve leaks through during freeze cycle. Check water inlet valve.
8. Connected to hot water. Check for bleed through from missing check valve in building water supply.
9. Incomplete harvest. Check harvest system.
10.High pressure cut out opened. Check fan motor pressure control, check fan motor, check controller using test mode.
11. Fan motor pressure control open. Check fan pressure control.
12. Fan motor not turning. Check fan motor, check fan blade,check controller using test mode.
13.Water pump not pumping. Check pump motor,check controller using test mode.
14. Pump hose disconnected. Check hose.
15. Compressor not operating. check compressor contactor, check controller using test mode.
Check compressor start components, check PTCR resistance and temperature, check compressor voltage, check compressor windings.
16. Low refrigerant charge. Add some refrigerant and restart unit. If cycle time imporves, look for a leak.
17. Hot gas valve leaks through during freeze. Check hot gas valve for hot outlet during freeze.
18. Thermostatic expansion valve bulb loose. Check bulb.
19. Thermostatic expansion valve producing very low or high superheat. Check evaporator superheat, Change TXV if incorrect.
20. Compressor inefficent. Check compressor amp draw, if low and all else is correcy, change compressor.
My counter top ice maker is screaming loud and I am wondering which part is making all the noise. I am looking at the condensor cooling fan and it spins without binding. The motor that dumps the ice works...
the noise is came from your compressor due to long uses or operation the mechanical inside possible for wear and tear you need to replace compressor before you replaced try to observe its operation.
3answers
My newair A1200ss stopped making ice. i tried recycling the unit and it has ample water, but the ice tray just stays in the down position. thanks.
I have had the same problem with two different portable ice makers, the ice tray inside is broken so you will have to send it to them and get it fixed. Hopefully eventually they will make the tray out of a stronger plastic.
Top New Air Kitchen Appliances - Others Experts
john h
Are you a New Air Kitchen Appliances - Other Expert? Answer questions, earn points and help others
