A dehumidifier works just the way an
air conditioner works
but in a reverse manner. If you encounter a problem with your
dehumidifier then it would be repaired the same way you would repair an
air conditioner. As such a dehumidifier does not require much cleaning
apart from changing the filter.
When the filter and coils of the dehumidifier are choked with dirt,
it may not pull out moisture from the air properly. The efficiency of
the dehumidifier gets decreased and the only solution is, to clean it
thoroughly. In order to assist you with the cleaning procedure of a
dehumidifier, following are a few tips:
Remove the water tank/container and clean it after
draining the water. Depending on the usage the container must be
cleaned regularly.
Cleaning or changing the filter is also important for the main function
of ensuring a healthy atmosphere is performed by the filter. Mix some
bleach with warm soapy and clean the filter. It will help to get rid of
the bacteria, molds and mildew.
Use a vacuum cleaner to clean the evaporative coil/hot coil. Scrub off
the dirt using a brush but make sure that you don’t bend the fins while
cleaning.
Clean the condenser or the cold coil the same way. If the humidifier is
working in a room where the temperature is below 60 degrees Fahrenheit
then check the coils whether it is not icing up.
See to it whether the fins are bent or not, if they are bent then
straighten them out using a fin comb otherwise it might obstruct the
effective working of the dehumidifier.
And yes do not forget to clean the fan blades and other parts of the dehumidifier.
Keeping in mind the humidity level of your room, sets the humidistat of
the dehumidifier as keeping it too low or too high may only make the
dehumidifier to run longer than necessary.
Also before you start with the work of cleaning the dehumidifier, make sure that it has been unplugged.
