SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
SOURCE: While driving scooter rear will sometimes shutter
Yep There are 3 possible problems 1. Make sure that the key is out of the lock before reinstalling the battery pack. 2. The controller is overheating. Let it rest 10-15 minutes to cool down if it happens again and 3. I think you are having a brake problem where the brake is not fully disengaging from the motor and causing excess drag on the motor.
You can remove the brake from the rear of the motor being careful not to break or pull the wires going to the brake. Tie the brake up away from the motor keeping the wires intact. Try driving the scooter and see if it still shutters. If it doesn't then you can use it like that but you will have no brake and if you use ramps it is dangerous. You can carefully remove the brake pad and give it a good cleaning along with the face of the motor where the brake pad rubs. Then reinstall all the parts and try your scooter again. The shuttering should stop and to excess overload of the motor should stop too. You could replace the brake by contacting Pride Mobility @1-800-800-8586 and talk with tech support to find out if you can just replace the brake assembly. Hope this helps you
make sure you have the batteries installed correctly positive to positive
