According to the South Seas Spas Owner's Manual, the filter cycle begins 6 minutes after the spa is energized and the second filter cycle begins 12 hours later. The filter duration is programmable and can be set to 2, 4, 6, or 8 hours for continuous filtration (indicated by "FC"). The default filter time is 2 hours.
It's possible that your filter cycle duration is set to continuous filtration mode. To change the mode, press the "Warm" or "Cool" button and select a duration of 2 hours.
If this doesn't resolve the issue, it's recommended to contact a professional technician for further assistance.
In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
go into the menu , phone set up scroll around until you get ring time/ duration and set for the desired no of rings before answer machine cuts in
down load a pdf version of the user manual for your system
dear go to setting there is a option to auto reply in how many seconds or beep kindly set it on your desired time it will automatically reply after that time duration.
Basically, you want to disable Forward No Answer to voicemail:
Feature ** CONFIG
Terminals&Sets
enter ext #
advance past Line Access to Capabilities
go to Fwd No Answer
CHANGE softkey to None
go to Fwd On Busy
The answer is on pg 12 of the manual, which can be viewed here: http://ebookspdf.s3.amazonaws.com/gadget/LG-FB163-Manual.pdf
Press clock for two seconds. use the track forward and back to set the type (12 hr or 24 hr).. press set. use track forward and back to set hour. press set use track forward and back to set minute.
press set
If you are watching a tape, simply use the FF button to skip forward until you see that the commercial is over, and then press PLAY to resume playing. If you are watching a live TV program, the short answer is - you cannot. You need a PVR or TIVO or such device to be able to do that - and even then you have to be time shifted back at least the duration of the commercial you want to skip first!
Check out the instructions for setting forwarding no answer. *7104 xxx # sets the forward and the time it requires to forward is settable in the *713 ss where ss is the number of seconds from 00-99.
A ring cycle is 6 seconds, so 24 would be about 4 rings. Once you set forwarding, you really don't have to cancel it, as even if someone is on the phone, the call waiting and display tell you who is calling and you have the timer time answer or ignore the call.
This procedure allows your iPhone to ring for longer or shorter periods
than the default setting of 20 seconds before voicemail answers. ***
Attempt at your own risk but if you pay attention to the keys you input
and follow the directions you should have no problems.
1. On your phone, dial *#61# and click Call
The screen will display:
Setting Interrogation Succeeded Voice Call
Forwarding When Unanswered Forwards to
+1xxxYYYzzzz Enabled
2.
Write down the xxxYYYzzz number (including +1) - this is the number to
your voicemail.
3. In order to make the
+ appear on the keypad in the next step you'll have to hold Zero down
for a few seconds, then it will become a Plus (+). Dial
**61*+1xxxYYYzzzz**30# and hit Call. +1xxxYYYzzzz is the number you
wrote down previously, 30 is the delay in seconds. The delay can be set
in 5 second increments, 30 is maximum.
4.
Dial *#61# to verify that the new settings are active.
5. Verify working voice mail.
If you find you or your contacts are not being forwarded to
your voice mail you have incorrectly altered your voice mail forward
number.
To find out what it is and try
again:
Dial ##002# and send. This will
reset that forward number to factory defaults.
By then Dialing *#61# you will again display the your
current (default) voice mail forwarding number.
Return to step [2] and continue.
*** Use this tutorial at your own risk ***...and if you have
the time you can always give AT&T a call to have them change the
number of rings on an incoming call before Visual Voicemail kicks in. I
was able to quickly change the duration on my own, using these
diagnostic iPhone GSM codes. The default time duration before Visual
Voicemail intercepts the call is set by AT&T to 20 seconds. You will
be able to add another 10 seconds yourself, but if you want your
callers to wait more than 30 seconds before voicemail picks up then
you'll need to contact AT&T technical support - they can change the
duration to 45 seconds upon request.
