MY brand new Reebok ZR9 treadmill has an error code 5 on it and it just stops completely when I am running! Any ideas>? Not sure if I am supposed to lubricate the belt before first use!
Exactly same just happened to my brand new Zr9 (error 5). Reebok said they would replace the motor or complete tredmill or my money back. Undecided as to what to do but thought i was buying a reliable bit of kit ??? They do cover it with 2yr warranty and it is really nice use, will research a bit more before deciding.
SOURCE: treadmill belt slipping
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem.
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
SOURCE: Reebok treadmill
Hi James
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled.
Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt
centered. Plug in the power cord, insert the key and carefully
walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
SOURCE: How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
