Microtek ScanMaker 3630 Flatbed Scanner Logo
Want to install microrek 3630 scaner for windows 7
Driver not found
There are no windows 7 drivers for that scaner.
Necesito instalar mi scanmaker 3630 necesito driver, y con cual programa puedo scanear mis fotos
English please, write up your request use google to translate it, then post it.
I need the driver for hp scanjet 2200c for the windows 7
Hi:
Check out this site it may be of some use to you, Hp does not support this scaner for windows 7. you will have to use microsoft scaner software to use it with windows 7.
http://hpanswers.blogspot.com/2010/02/hp-scanjet-scanners-windows-7-drivers.html
My scaner is epson stylus cx3700 but i can no use the scaner in window 7 what can i do to make it work
Hi semidgs !
Unfortunately , there are no drivers anymore for your device under Windows 7 64-bit system but well under 32-bit system .
Here is a workaround :
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.Back up your data first.
Both are easy and safe , no specific knowledge required .
I have installed Windows XP on my secundary ( Windows 7 on primary ) and everything is working fine .
Regards .
1helpful
I LOSE CD DRIVER FOR SCANER MUSTEK 1200 UB PLUS AND I CAN T INSTALL SCANER FOR SCAN
Hi. If you are using Windows XP or older version of Windows, you may download the driver at:
http://www.mustek.com.tw/Download/driv_scanr/english/1200ubplus.html
This is an older model and doesn't have drivers for Windows Vista and Windows 7.
1helpful
Can't get windows 7 64bit drivers for Scanmaker 3630 Scanner. Any ideas?
ideas yes will they work probably not if you have a copy of server 2008 windows you can pull the driver from the disc it might work or craiglist the scanner and buy a new one SORRY no driver exists and i doubt one ever will it is a discontinued bottom of the line product
2answers
Lost the disk to instolle the scaner. how do i download it
Hello, and thanks for using FixYa.
The drivers are also available from the makers website here - http://support.microtek.com/product_dtl_2.phtml?prod_id=5
You may download the drivers from the above page, they are on the bottom of the page, just select the appropriate windows version that your computer has.
Please let me know if you require further assistance or if you have any questions.
Thanks,
Ekse
3helpful
I would like to get "Microtek Scanmaker 3630 Driver For Windows 7". Thank you
as this is a discontinued product the driver for windows 7 is not yet available any way you may visit "http://202.39.72.2/Singapore/Web/driver-page/discontinued.php"
and download driver and install this may also help in windows7
Printer not work in windows 7
You may have to go to the printer manufacturers site and download updated drivers for Windows 7
Mar 06, 2010 • Plumbing
3helpful
Driver para windows 7 scaner artiscan 9600
poseo un escaner CanoScan N 340P, trabajo con plataforma windows 7, no me funciona el escaner, que puedo hacer?
Top Microtek Office Equipment & Supplies Experts
Alexander
Grand Canyon Tech
Grand Canyon Tech
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
