Question about Konica Minolta Magicolor 4690MF Multifunction Laser Printer
I have a Konica Minolta 4690MF and have black toner all of my paper when printing.
The other color toners aren't all over the papers when I print - only the black. I have tried using the cleaner sheets but I think it is more than dirty rollers.
  • Konica Minolta Master
  • 6,850 Answers
Replace the black image unit and are you using third party toner if so get OEM
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 16, 2016
SOURCE:
SOURCE: Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
Posted on May 27, 2008
  • 5 Answers
SOURCE: Toner Not Installed - After replace black
This is actually a desigbn fault on the magicolor printers. Underneath the toner rack is the 3 pin chip reader - normally white and plastic with 3 metal contacts sticking out.
it is at the bottom of the printer so very often toner drops onto it and the sensors dont work, it also takes a bit of a beating as the cartridges rotate. Its very easy to replace - but you need the part,
Minolta should have put it at the top rather than the bottow where it gets covered in dust.
these guys helped me a lot
http://www.zinetic.co.uk
Posted on Feb 22, 2009
SOURCE: Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Posted on Oct 15, 2009
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
SOURCE: My Konica Minolta MC2300DL will not print. It is
You can change the 2300's menu setting to ignore empty toner cartridges and keep printing. There are 2 steps:
Step 1:
Press Menu/Select, then "right arrow" until you see ENGINE. Press Menu/Select again and then "right arrow" until you see TONER EMPTY. Press Menu/Select and you'll see STOP. Press "right arrow" once to change to CONTINUE. Press Menu/Select.
Step 2:
Press "right arrow" until you see AUTO CONTINUE. If set to ON, press the "Cancel" button and you're ready to print. If set to OFF, press Menu/Select, then right arrow to change to ON, then Menu/Select to enter. It will say "ON IS SELECTED." Then press the "Cancel" button and you're ready to print.
Posted on Apr 07, 2010
Konica minolta 4690mf color streaks
replace the image unit for yellow and magenta
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 22, 2014 | Konica Minolta Magicolor 4690MF...
Konica Minolta Bizhub c754e Blue Lines after installing new machine
The blue toner cartridge or drum are damaged. First, try a different toner cartridge. This will probably eliminate the lines.
Apr 08, 2014 | Konica Minolta Office Equipment & Supplies
Paper is completely black
Please check if you have filled the toner with non original toner because most likely thats the problem, bad toner not compatibel to konica minolta toner.
Jan 25, 2014 | Konica Minolta PagePro 4650EN - Printer -...
Konica Minolta Magicolor 2300W not transferring toner to paper.
Clean the paper feed rollers,the fusing unit rollers and print the blank page(min.10-15) for clean the upper fuser hot roller.Agiting the toner.
Jan 28, 2013 | Minolta magicolor 2300W Laser Printer
Poor print quality
The "ghost" image is "burned" onto the drum.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
You need to replace the drum.
Apr 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
When color toner is out, is there a way to run with black only?
yes.... go to the printer and faxes under the start> settings menu .....right Click the default printer it has a check mark by the icon......then go to printing preferences under ink click black.... hope this helps ...this is info for 2000pro
Sep 21, 2009 | Konica Minolta Magicolor 4690MF...
Color line along side of copies; doesn't always print; error message keeps blinking (no manual),
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
May 27, 2009 | Konica Minolta magicolor 2400 Laser...
Either to got a bad cartriage or the opening is not releasing enough toner
Apr 02, 2008 | Konica Minolta magicolor 2400 Laser...
Konica Minolta Magicolor 4690MF Multifunction Laser Printer Logo
97 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
