USB flash drives are small, convenient storage drives. Place data such as pictures, photos and text on them quickly and efficiently and then carry it to another computer for copying to its hard drive.
A USB flash drive that has security enabled in it must be 'unlocked" before it can be used, which becomes difficult if the password has been lost. Because the security on the USB flash drive is rudimentary, a number of methods, from built-in software to optional programs, can remove the security so that the drive can be used.
Plug the USB connector of the USB flash drive into a USB port on the PC. Right-click on the icon of the USB flash drive when it appears on the desktop of a Windows-based computer. Select "Format" from the pop-up menu. Follow the command prompts in the window that appears to format the USB flash drive. Click "Done" in the confirmation window when it appears. The USB flash drive can now be used because the security has been removed from its storage space. Plug the USB connector of the USB flash drive into a USB port on the Mac. Double-click on the Mac's Disk Utility program, which comes free with the OS X operating system and is in the "Utilities" folder on the hard drive. Select the icon of the USB flash drive in the left column of the Disk Utility program's main screen. Select the "Erase" tab at the top of the Disk Utility program's main screen. Click on the "Format" check box on the right side of the Disk Utility program's main screen. Select "Fat (32)" from the drop down menu below the "Format" check box. Click "Format" at the bottom of the Disk Utility program's main screen. Click "Format", again, in the confirmation box that appears. Quit the Disk Utility program when the formatting is done. The USB flash drive can now be used because the security has been removed from its storage space. Download a password protection program to the computer's desktop; for example, the free TrueCrypt password protection program (see the link in Resources). Double-click on the icon of the password protection program when it has fully downloaded. Follow the command prompts to install the program onto the computer's hard drive. Restart the PC after the installation has been completed. Double-click on the password protection program to launch it. Wait for the password protection program to recognize the USB flash drive and display disc letters for the drives attached to the computer in the left column of its main program screen. Plug the USB connector of the USB flash drive into a USB port on the computer. Wait for a letter to appear in the left column of the password protection program's main screen. Use the mouse to click once on this letter which represents the USB flash drive. Click on the "Volume" or "Volume Tools" button to open a new window. Click on the "Next" button in the new window. Erase the password in the "Password" column of the new window that appears. Erase the password in the "Confirm password" column. Click on the "Next" button to go to a new screen. Select "Traveler Disk Setup" from the drop down menu below "Tools" at the top of the password protection screen. Click on the "Open Explorer window for mounted volume" check box in the new window that appears. Click the "Create" button at the bottom of the window. Click the "OK" button on the confirmation window when it appears. Quit the password protection program. Drag the icon of the USB flash drive to the Trash or right-click on it and select "Eject" from the pop-up menu. Remove the USB flash drive from the computer's USB port. Plug the connector of the USB flash drive back into the computer's USB port. Double-click on the icon of the USB flash drive when it appears on the desktop to open its window now that the security password has been removed. Plug the USB connector of the USB flash drive into a USB port on the PC. Go to "Start" and select "Run" from the pop-up menu. Enter "regedit" into the text column that appears and press the "enter" key to run the registry editor. Press the "Browse" button on the registry editor's main screen and navigate to the following path on the computer's hard drive: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies" Click "OK" to close the window. Double-click on the "WriteProtect" text that is in the right column of the registry editor's main screen. Enter "O" into the "Value Data box" in the window that appears. Click on the "OK" button to close the window. Quit the registry editor program. Restart the PC. Double-click on the icon of the USB flash drive that is on the desktop to open its window and access the files now that the security write protection has been removed. Hope this helps
The hard drive has issues, or windows files have been corrupted, Remove hardware from the laptop and reseat it back in place, sometimes this is enough to get it started, if no change! do a operational install with the cd installation disc, if this fails the hard drive should be assessed for replacement.
Make sure it is inserted all the way into the usb port. If nothing comes up, this doesn't mean it isn't connected, it just means autoplay isn't on. Once it is plugged in, go to the start menu > computer. This will open a folder with all your drives, both internal and external. Double click on your flash drive's icon to open it.
Check if your hard rive indicator light is flashing (has disc shape icon or can shape icon next to it). If it is then put in your windows disc and do a startup repair. Make sure it is booting from the disc drive first. if it isnt flashing then you may have a dead hard drive. Try taking the hard drive out and putting it back in.
Could very well be that the external hard drive is drawing more power than what the player can deliver - it is enough for a usb stick but not for the external drive. Now if you use an external drive that is self powered I am sure there will be no issue.
Remove the USB flash drive from the USB port on your computer. Restart the computer and wait for the operating system to finish loading. Plug the flash drive back into the USB port and attempt to access it again in case the computer stopped recognizing the drive for some reason.
Transfer any files on the flash drive to the hard drive of your computer if the USB flash drive has any functionality at all.
Open the Start menu by clicking on the Windows icon on the bottom tool bar. Click on the "Control Panel" link. Scroll down through the list of available options and click on the icon labeled "Administrative Tools" that has an image of a box filled with check marks.
Find the Computer Management icon at the top of the window and click on it. Wait for a new window to appear on the screen and click on the "Continue" button to bring up the Computer Management window.
Locate the "Storage" entry on the left side of the Computer Management window. Click on the black box next to the entry to expand the menu. Click on the "Disk Management" icon that appears below the Storage entry.
Right-click the name of the the USB flash drive that appears at the center of the window. Click on the option labeled as "Format..." from the menu that will pop up. Select the "FAT16" option from the first drop-down menu and click on "Start" to format the flash drive.
Return to the Control Panel and click on the "Device Manager" icon. Scroll down to the entry labeled as "Universal Serial Bus Controllers." Right-click on the entry for your USB drive and choose "Update Driver." Wait for the latest USB driver to finish downloading and then attempt to use the flash drive again.
The icons from the left:
1. Power indocator
2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive.
3. Power Source indicator
4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Regards,
Dapid Candra
sdkoukal,
Sounds like it is overheating or a connection issue, your probebly going to have ot call sony and see what they say. If this doesn't answer your problem please post again.
Please post what you do and how you did it.
I look forward to your posts.
