KLH CDR2000 2-Disc CD Recorder Logo
A
Anonymous Posted on Feb 20, 2014
Wich cd will record this sistem - KLH CDR2000 2-Disc CD Recorder
1helpful
How do i fix my Technics cd player wich only read some original music cd's, most of them just spins and are not recognize, please help me
Hello Pedro!
many old cd-player suffer trouble to read some original cd, this can be the lens assembly worn out or simply dirty on it, to solve this you need to open the player, then remove the disc upper holder if present and clean the lens with a cotton swabs or a simply cloth with alcool. then let it dry for some minutes. If you have compressed air you can free the player from dust.
In some cases is possible also to calibrate the laser power with the specific calibration screw trim placed near the laser lens, for to do this you need patience, move the screw clockwise some degrees and test the disc reading, if no success turn some degrees in the opposite direction until you reach perfect calibration.
Unable to set tv to record
Step 1:
please test the connection very well see the attached hookup .
You must sure if you unit DVD laser eye is clean?. Use the DVD --CD cleaner Disk. Test the wires for open or faulty. Clean the connector wires from dirty+corrosion.Use the contacts cleaneer and try again.2_9_2013_11_45_11_am.gif
Step 2:
Step 3:
If the problem persist, the Pick up sistem is defective.
God bless you
Realtek ac97 line in recording problems
you must configure the record system. Be shure if you virus, malware, had been penetrated in your sistem.
if the machine was working before recording, restore the system.
God bless you
What i have to do for reset my desktop?
you will need to re-install the operating system.
insert your cd/dvd with operating system and boot from dhe cd/dvd drive.
follow the on-screen instructions
4helpful
DEAR SIRS I HAVE BUY LG PORTABLE SUPER MULTI DRIVE GP10 I TRY TO INSTALL THE DRIVERS, WHEN ISTALLED THE DRIVER I WANT RECORD A CD OR DVD THE SISTEM MENTION THAT A ERROR AND THE CD OR DVD IS WRITE...
I had buy a LG Portable Super Multi Drive GP10 and the LG Power Tool software does not have a Video Player. The Help Section of the software show the icon Video Player but it does not appear in my software. Besides, the Windows Media Player does not work for videos. Are there any solution in order to get de Video Player drive or software?
How to connect sharp cd-ba 1700 to pc?
if your sistem got auxiliar option,you can connect your pc through the earphones output of the pc to the auxiliary inputs on the shelf sistem they are a cable named 3.5mm to rca outputs to fit that connection gfood luck
Problem with audio cd-recorder LG adr-620
First of all, CD-RW will not work in most regular CD players.
CD-R should work in other players but you will need to finalise them first. Refer to your manual on how to finalise a disc. Once finalised your discs should play in 99% of machines. Only very old machines (from the 80s) might have problems.
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
NOEL
NOEL
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
