The Wii console will not accept game discs or the discs are ejecting immediately
What To Do:
Press the eject button on the front of the console. The console will not accept any discs if there is already a disc inserted, and it is common to forget that a disc was already inserted. If the system still won't accept discs, or if the discs are immediately ejected, this indicates a problem with the mechanism that pulls the discs into the system and the Wii will need to be repaired. To begin the repair process, click here.
Well I think thast the disc drive is broken or there might be something stuck inside of the wii console like coins keep video games consoles out of reach from little kids they will reck video games consoles then.
There's either something jammed inside of the Wii's DVD Drive, or a part on the inside of the DVD drive is broken. All drives have a sensor on the inside to let it know that a disc is fully loaded and seated. If the sensor isn't engaged within a few seconds, it will spit the disc back out.
You can find a new DVD drive at the following website:
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide,
that gives step by step information on Dis-Assembling with screenshots,
even a novice can fix the disc eject problem with the help of this DIY
Guide. It also gives information on fixing many Wii Related Problems,
so its a kind of Wii Problems Reference Fix Guide
I've found that this is usually caused by a problem with the small plastic gears that operate the loading mechanism. Sometimes they break, need to be realigned, or get stuck.
If one or more of them have a problem then the loading mechanism never allows the disc to drop onto the motor to spin. Then the Wii realizes that the disc did not load properly and kicks it back out.
But the only way to see is to take the Wii's cover off.
