3Com NBX 3102 IP Phone Logo
A
Anonymous Posted on Feb 19, 2014
Web page + 3102 - 3Com NBX 3102 IP Phone
NBX_Tech
Level 1:
New Friend:
  • Contributor 58 Answers
  • Posted on Apr 04, 2014
NBX_Tech
Contributor
Level 1:
New Friend:
Answers
58
Questions
0
Helped
23438
Points
63
You can't web to a 3102 phone, only the phone system. If you don't know what the IP address is on the phone system, you will have to get a serial cable (null modem cable) DB9 male to DB9 female and connect to the console 1 of the phone system. You will need a terminal emulator program and connect at 9600, 8, none and 1 for the settings. Type nbxIpConfig (case sensitive) and hit enter. The IP address will then be shown. If this is not what you were asking, please explain.
Reset 3com 3102
Hi Chirag,
On the web interface, use
1 Click System Maintenance > Purge Data.
2 Click Purge Database
This ll do fact reset.
HTH
-Karthik.
My Bissell easyvac is nolonger picking up rpoerly, I cannot find the user manual. What can I do?
You can download the user manual from the manufacturer's web site at
http://www.bissell.com/DownloadAsset.aspx?id=577
Destroyit 3102 drive gear part number
The part number you need is 2601 062 as long as your looking for the gear that meshes with the motor shaft. The price is around 25.00 dollars and phone number for destroyit or as known MBM corp. 800-223-2508
Hope this helps leave feedback if so. If you have trouble getting part contact me i'm a dealer and can get you the part.
Need manual for 3102FB Necchi
I found a 3102 here - http://www.sewingstyle.com/Necchi-Sewing-Manuals.html
However, I would check with the merchant before ordering to be sure it is the correct manual for your machine.
1helpful
Magenta smear over half the page Minolta CF 3102
i would start with replacing the magenta image unit yes
1helpful
192.168.1.2 - i can't get into this with or without http://
You need to have a wired network connection between your pc and the 3102, using an ethernet cable. Once you have that and the light are on on both ends of the connection, go to Control panel, Network Connections and identify the connection, normally Local area Connection.
Right click and edit Properties, look for TCP/IP and change it from automatic to set as 192.168.1.10 with a subnet mask of 255.255.255.0
Don't bother about any of the rest. If it is already set up manually, MAKE SURE you note down all the settings before you change anything.Then open a web browser to 192.168.1.2 and make sure you click on Admin and Advanced on the toolbar. You can turn off call waiting from there if it is set up, but I don't recall the 3102 as supporting it. Frankly, the 3102 is a POS, and you should replace it.
Cant connect additional 3102 to nbx. Please help!
3102 phones require group 2 licenses purchased from an authorized NBX reseller. if you don't have enough the system will not allow the phone to be discovered. You can check this unler the licenses tab while logged into the phone system as administrator.
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
