Motorola Mobility XT907 DROID RAZR M Verizon Unlocked Black Logo
A
Anonymous Posted on Feb 19, 2014
Will not turn on, green lite blinking - Motorola Mobility XT907 DROID RAZR M Verizon Unlocked Black
Blinking green LED lite. No power. L46wd22
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
4helpful
The power light on my DS Lite keeps blinking even when its green, and I swear I have never seen that happen before, what does it mean??
A blinking green light usually indicated that your connected to a wifi connection or a ds to ds link.
3helpful
Green lite turns on for 2 second and then turns
Please listen and try this:
When the power light comes on and goes off, on the front of the set press BOTH the Menu and Input (Device) buttons at the SAME time and HOLD them both for at least five seconds and then release both.
The power light will blink a two digit error code and will repeat it about 5 times. To get it to repeat you would have to unplug the set and turn it on again etc.
The most common error is 2 blinks, pause, 2 blinks.
Let me know what error code you find and I will direct you as to what it means and what may have to be done.
SD TECH
2helpful
The green lite is blinking and the tv will not
The steady blinking led is indicating that the DM isnt completeing the boot sequence, which usually is caused by failed capacitors. You can get the V26 DM repair kit from www.tvrepairworld.com which should repair that issue. The kit contains the replacement capacitors and the CD with detailed instructions.
1helpful
2answers
1helpful
My nintendo lite wont turn on-the green lite is on but thats all-
Which LCD is blinking?
If your top screen is blinking before cutting off, your DS lite has a problem with the bottom screen.
If the bottom screen blinks before cutting off, your DS lite has a problem with the top screen.
Can you confirm?
1helpful
Toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Green power lite blinks but does not turn solid green
check the lamp...lamp cover under front panel on left... take out lamp (unplug TV befor doing this) and see if it is broke ....if lamp is good replace it and put it back together plug set back in and try it agen some times the conector dont make good contect so just taking out and in fixes it..... also lisen to the set when you turn it on most of the time there is a little buzz when it is trying to fire the lamp if the buzz is not there it maybe the ballast board
good luck
2helpful
Power lite blinks red and will not turn on
Sounds to me like you're experiencing an issue with the power supply in the unit.
2answers
Sony LCD projection TV - bulb problem
Hi! sweet123,
Please answer this question. Were the 4 bulbs visabley bad; say broken or did they have a milkey look, or broken wire inside? In other words did the bulbs you replaced look as good as a new unused bulb? Please reply.
toprol
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
