Dirt Devil Easy Steamer Upright Wet/Dry Vacuum Logo
A
Anonymous Posted on Feb 19, 2014
Water will not come out - Dirt Devil Easy Steamer Upright Wet/Dry Vacuum
Lincat CombiMaster Plus rational flashes H2O and open when it's been on steam for about 30 minutes
It sounds like there may be an issue with the water system on your Lincat CombiMaster Plus combi oven. Here are some troubleshooting steps you can try:
  1. Check the water level: Make sure that the water level in the tank is sufficient and not too low. If the water level is too low, it can cause the "H2O" warning to be displayed.
  2. Check the water inlet: Make sure that the water inlet is not clogged or obstructed and is able to provide a steady flow of water to the oven.
  3. Check the water pump: If your oven has a water pump, make sure that it is functioning properly and is not damaged. A damaged water pump can cause the "H2O" warning to be displayed.
  4. Check the water hose: Make sure that the water hose is properly connected and not kinked or damaged. A damaged water hose can cause water to leak out of the oven.
If these troubleshooting steps do not resolve the issue, it is possible that there is a problem with the water system or another internal component of the oven. In this case, it may be necessary to have the oven repaired or serviced by a professional.
Oct 21, 2022 • H2o Vacuums
What kind of water is to be used in the steam station RHST 100. I mean to say that only distilled water is to be put or ordinary tap water can be used ?
hi.
distilled or de-ionised water is recommended in all steam generator units.
tap water can contain minerals and salts that will remain in the unit and fur the inside of the steam generator.
if you live in a soft water area where there are very few impurities in the water you should be ok to use the tap water.
if you are in a hard water area, do not use tap water.
the best way to work it out is look at the inside of your kettle.
if the inside is clean with no sign of scaling, the water should not scale your steam generator.
if there is any sign of scaling, do not use tapwater for your steam generator.
distilled or de-ionised water is recommended though
Apr 08, 2011 • Vacuums
2answers
How do i clean my iron so brown dirt won't come out of it when i iron
Brown water and white scale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
1helpful
Where do i put the water at in bissell pro heat?
The water goes in the funnel area of the water tank. this tank serves to handle both NEW water and dirty water, separated by a plastic bag..... Water only in this area....
Hi my Vacuum is a zante DV-4399 and i dnt know how to use it i turn it on and it doesnt **** it says to put water in it because it is a water filtration unit i got it from a friend and didnt get the manul...
This is water filter model which requires the regular water, tap water be poured into its container. The amounth of water is 1.5 liter (or 1.8-2 quarter) of tap water. This water is used to filter air coming into vacuum, so dust will stay in the water and after water becomes dirty you have to waste it and replece with fresh water. It CON NOT Work WITHOUT WATER, otherwise next step filter wil be dirty very fast and it will clog the air flow. And , by the way that filter is removable and should be periodically washed by fresh water. This is very good vacuum model !! I would like to buy it too but I can't find it. Do you know where your friend bought it? Please, find it out and send it to my email brrr0000 at yahoo.com Thank you too.
Aug 04, 2010 • Vacuums
2helpful
I have never used a shampooer before when I use it it says to empty out dirty water. I don't have any left. My tank is empty. Am I doing something wrong.
Suggest that you do the following.
Remove the TOP ("Clean water") tank. Fill it 1/2 full of water. Put the top on the clean water tank and place it back on the machine.
Release the machine handle and remove the cover of the "dirty" water tank. Inspect the back of the tank to be sure that the vacuum adapter in located in the rear of the dirty water tank. If not-that is your problem. If yes, restore the top to the dirty water tank.
Power the machine on.
On a kitchen floor, power the machine on. Pull the trigger and hold it for about 30 seconds. You should see water gathering around the brushes. If not, that is a problem.
With water around the brushes, release and lower the handle and and move the machine over the water. It should vacuum the water into the dirty water tank.
Is all of that happening?
2answers
What is aquaguard
water guard.. it means liquid won't harm it
3helpful
My Bissell Proheat 8910 does not spray water onto carpet.
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
I have a bissell quickwash 1950-e. I bought it Jan. 2006, and have only used it 8-10 times, I live in a very hard water area, so I though if I put some vinegar in with the cleaning solution it would get...
Hard to say what is causing your problem, replacing the cap and insert on the water tank may help, part #2041111, even tho it may trickle out water when depressed, they can still be bad. The other thing would be the rod not relesing the water like it should. The big draw back to this model is Bissell has obsoleted all of its parts and most are no longer available. Might be wiser to buy new.
Apr 13, 2008 • Vacuums
Water tank doesn't dispense water
water is not coming out or sucking up water
Top Dirt Devil Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
NOEL
NOEL
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
