Zyxel P660HW-D1 Router Logo
m
metalstampin Posted on Feb 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Key phrase i am unable to see wireless settings. i can see LAN only.
Peter
Level 2:
Habit-Forming:
  • Expert 82 Answers
  • Posted on Feb 23, 2014
 Peter
Expert
Level 2:
Habit-Forming:
Answers
82
Questions
0
Helped
27971
Points
154
First, go to this site - 660HW Series ZyXEL - and download a manual for the ZyXEL P660HW-D1.
Quick start guide
Download Library
Next, hook up the router to your computer with a LAN cable. Open a browser and enter 192.168.1.1 into the url address window. The default login is 1234. Then configure the wireless settings - see pages 6 & 7 of the guide.
Need helpetting up wireless connection
WIRELESS ROUTER SECURITY
When you power up the wireless router and the LEDs are ON then the router appears to be OK and this also applies to the DSL or cable wireless modem. To check if the modem is configured to your ISP settings and the modem connects to the Internet, connect the modem with a LAN cable to your laptop and check if you can get into the Internet. To connect to your wireless router, it needs the router's wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router's wireless settings. Then the laptops and desktop computers can communicate with your wireless router. To set-up and secure the wireless router from unauthorized access, follow these steps: - 1, Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA). The encryption key can be easily set up using a passphrase (it can be an alpha numeric phrase or words). 7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Twher can i find my wap pass phrase
The WPA encryption key is in the wireless setting of your wireless router.
Some later modelwireless routers have the Password (ie.Encryption key) and the SSID alreadyconfigured in the wireless router and this information is printed on a label onthe bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
I need to know the network key for my Linksys routerWRT54GL-EU in order to establish a wireless LAN to my PC (a Fujitsu moidel) Best regards, Preben Lund [email protected]
When you first installed your router, you used the "Wireless Networking Setup Wizard" to"
* set an SSID ("network-name") for your network.
* set an encryption-level. Hint: use 'WPA' or 'WPA2'.
* set a password or pass-phrase for your network.
Enter that password. Or, rerun that Wizard, to create new settings.
Linksys 64bit passphrase
The passphrase is a phrase you create instead of using hex numbers (phrases are easier to remember than hex numbers) to setup the wireless encryption key.
To configure the Linksys wireless setting, connect a LAN cable from the Linksys LAN port to the computer's LAN port. Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
Then go to the wireless settings and configure the SSID and WPA or WPA2 encryption.
Use a passphrase to setup the encryption key
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
I am using time warner cable high speed internet. and trying to connect my ps3 through a belkin router but it is not working. the wireless icon pops up from the router but what is a WPA Key??? HELP!!!
WPA === Wireless Protected Access
It's a level of encryption between the router and each wireless device, to add "security" to your wireless traffic.
Use an Ethernet cable to connect the network-port on a computer to one of the LAN ports on the router.
Restart the computer.
Start Internet Explorer, and connect to the web-server "inside" the router.
From this web-interface, you can set an SSID and set the encryption-level (e.g., WPA) and you can set a password/pass-phrase/pass-key for your wireless network.
Use the same SSID and password on your PS3.
Security key
Use an Ethernet cable to connect your desktop/laptop to one of the LAN ports on the router. Launch Internet Explorer, and connect to the web-server "inside" the router. Run the "Wireless Networking Setup Wizard", to enter an SSID, enable 'WPA' encryption, and to set a security-key or password or pass-phrase.
What is wpa pass phrase while setting wireless printer
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
Thanks for using Fixya,
I did not know my network key for wireless lan, Satellite L300 se
The network key is an encryption key ie. WEP/WPA-PSK key.
This key is configured in the wireless setup of the wireless access point or wireless router.
The key can be a hexadecimal number but most people use a Passphrase.
The Passphrase can be a phrase such as "I'm am so smart 12345" and this is used to generate the hexadecimal encryption key.
For instructions on setting up and configuring the wireless security for your access point (this apply to wireless access points and wireless routers), please click in this link and follow my instructions :-
2answers
Passphrase my isp does not have this information either
I understand that you are trying to connect the wireless adapter in your notebook computer to the wireless network being offered by your own router.
Login to your router's web-server, and query the pass-phrase it is using, or reset the pass-phrase.
1helpful
Having problems with the security key/passphrase
u will be able to find the secutiry key at the back of ur modem or at the router page. let me know the router name if unable to find the wireless key still
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
